Ram Air ???
Old Aug 31, 2008 | 07:34 PM
mugzilla's Avatar
is Fast Enough ...
Ram Air ???
On this video at 5:05 you see a pic under the hood that shows
an open air cleaner and this looks like a factory video.
http://www.youtube.com/user/vistacruiser67
Old Aug 31, 2008 | 08:00 PM
69Rman's Avatar
It looks to me like they have just "flipped their lid" like I've seen discussed in these forums. lol
Old Sep 1, 2008 | 02:20 AM
Bluevista's Avatar
Registered
Uh... Ram Air is Poncho terminology I think. (some people are really touchy about those things here)
That is weird, the car has the outside air ducting and they flip the lid over?
Probably did it so when they were filming you could here the noise when the secondaries kicked in and it hit passing gear with the automatic, bwooo-wahhhhhh!!
Allan
Old Sep 1, 2008 | 04:01 AM
Here's the tread that discussed this 68 H/O a little while back
https://classicoldsmobile.com/forums...90-68-h-o.html
Old Sep 1, 2008 | 06:47 PM
mugzilla's Avatar
is Fast Enough ...
Red face oops
I even posted in it ...
Old Sep 1, 2008 | 06:53 PM
Definitely different than ram air on a 1971 or 72. Wouldn't this be the same setup for 69 as well?
What a cool video. Where did you get it? I really loved the sound of that BB with the pedal mashed. One thing that I wouldn't want to be doing is a wack of those brake tests from 60 and 70 mph a bunch of times. Polyglas tires back then weren't radials, just bias plys. Definitely going to feel the flat spots that it causes on the rubber. Holy cow, did you see how well controlled the roll was on corners? Those stabilizers and springs really made a difference. Bet they wish anti lock brakes were around back then.
Now I want a time machine so I can go back and buy a couple of those bad boys. Only 515 made? Wonder how many are still surviving? Got any more of these wonderful ads?
Old Sep 2, 2008 | 03:52 AM
Well, Yes and Nope. 69 W cars yep, 69 H/O nope.It is a one year only with a vacum operated flapper door in the [grey] top can.
But please call it OAI [Outside Air Induction] not "ram air"
Old Sep 2, 2008 | 06:58 AM
For trivia buffs, the flapper door and O.A.I. top plate used on the 69 H/O are the same parts as used on the Ford Cobra Jet cars. The vacuum actuator even carries a Ford part number.
Old Sep 2, 2008 | 10:03 AM
mugzilla's Avatar
is Fast Enough ...
I guess I should tell you I'm heavy into a-bodies ( Mr. GTO ) Goats, Icks, no {deletes}...
When I had trouble finding Rear springs for my 442 I eventually went with standard
Var ratio cargo coils and I corners nicely ...
Which brings up a Question. I've heard that the rear on a 442 should sit slightly
lower. The car in the video looks low. Make the rear end push the body more ???
Mine is up slightly but it still works great ...
I really like how it looks without the trim on ...
Old Sep 2, 2008 | 10:05 AM
mugzilla's Avatar
is Fast Enough ...
Go back from here to see recent work ...
http://s72.photobucket.com/albums/i1...lla/?start=540
Old Sep 2, 2008 | 05:06 PM
88 coupe's Avatar
Junior Member
Originally Posted by amh555
Ram Air is Poncho terminology ........
Yes it is. Thanks for posting the correction.
Norm
Old Sep 18, 2008 | 07:30 PM
z11375ss's Avatar
Senior Moment Member
My 68 sits low in the back too. I put on aluminum heads and intake and it raised the front by an inch more. Now it is really pronounced. So time to get new springs and see if that will level it out some. I had a 69 and it sat a little low in the back as well. I and my friends thought this was the way Olds are supposed to be. Back in the day they were the cars that really HANDLED. LOL
Old Sep 18, 2008 | 09:18 PM
mugzilla's Avatar
is Fast Enough ...
I'm a big fan of progressive ratio cargo coils ...
I ordered a set from a vista cruiser and I really like the way it corners ...
It plants the tires at the drag strip also ...
Make sure you get new spring isolators also. I made a set out of some
nice stiff neoprene and they work nicely ...
Bernhard
Apr 27, 2013 10:54 PM
WTony
Feb 20, 2012 02:05 PM
jimjr
Jan 28, 2011 07:23 AM
StickW31
Feb 25, 2010 01:14 PM
WTony
Hurst/Olds
Oct 29, 2009 10:54 AM
