Qudrajet Fuel Leak
Old Aug 25, 2018 | 07:33 AM
rlafash's Avatar
Qudrajet Fuel Leak
The Quadrajet (#7027156) on my 1967 442 has begun to leak around the "pressed in plug" at the front of the bowl where the fuel filter is located. This was repaired in the past, prior to my ownership, with what looks like an amber colored, semi transparent epoxy. What is the recommended repair process? Is there a preferred sealant? The carburetor performs well and I'd prefer to retain it as it "appears" to be the original factory installed unit.
Old Aug 26, 2018 | 08:13 AM
shiftbyear's Avatar
I contacted Cliff Ruggles about your carb. First remove the old epoxy, then:
"Best method is to gently “peen” the material around the plug and re-seal it. I’ve done this countless times and to date never had to remove one of those plugs for another type of repair......"
The best epoxy to use is Marine Tex 1:1 ratio, available all over Amazon, Ebay...ect. Good luck
https://www.ebay.com/itm/Boat-Marine...QAAOSw9gRaKY1X
Old Aug 27, 2018 | 07:08 AM
rlafash's Avatar
Thanks so much for the effort and suggestion. I will follow up as instructed.
wr1970
Mar 20, 2017 05:06 PM
denf221
Jan 30, 2017 02:30 PM
Middian
Apr 18, 2016 02:30 PM
Don Roberto
Jun 14, 2015 05:51 PM
raywaco
May 24, 2008 03:59 PM
