Phosphated hood latch photos
Old Sep 29, 2010 | 08:42 AM
ROCKET VAPOR's Avatar
Lance
I recently purchased some zinc and manganese phosphate plating chemicals from Palmetto Enterprises.
http://www.palmettoenterprises.net/P...-Welcome-.html
The first part I did was the hood latch on my '70 442.
I was very pleased with the ease of use, and the final results.
So.... I thought that I would share some before and after photos.
Last edited by ROCKET VAPOR; Sep 30, 2010 at 11:19 AM. Reason: To restore lost photo link
Old Sep 29, 2010 | 08:48 AM
Lance
Some more after photos....
Last edited by ROCKET VAPOR; Sep 30, 2010 at 11:13 AM. Reason: To restore lost photo link
Old Sep 29, 2010 | 08:50 AM
firefrost gold's Avatar
nice
Old Sep 29, 2010 | 10:08 AM
X2
Old Sep 29, 2010 | 10:43 AM
stevengerard's Avatar
wow looks great, that would probably be a good thing to do on the hood hinges too, though not sure if it i correct for hinges
Old Sep 29, 2010 | 11:00 AM
Lance
Originally Posted by firefrost gold
nice
Originally Posted by Jamesbo
X2
Thanks guys, the parts look alot better in person though.
I put a very heavy coat of Boeshield on these parts and the Boeshield makes the plating appear to be un-uniform in the photos, but it is not.
Very pleased with the product as well. It was very easy to do.
Now I am just trying to spread the good word around about this product
Old Sep 29, 2010 | 11:07 AM
Lance
Originally Posted by stevengerard
That would probably be a good thing to do on the hood hinges too, though not sure if it is correct for hinges
This is the exact reason I bought this chemical, to do my hood hinges.
I did this test on the smaller hood latch first. Their zinc phosphate chemical that I used on the hood latch was a exact match to the light gray phosphate on my original hood hinges.
Old Sep 29, 2010 | 04:57 PM
H ow much clean up did you do on the first parts? Did you just put it in a bucket or what?
Old Sep 30, 2010 | 02:39 AM
Yellowstatue's Avatar
Plays hell with the test dirt doesn't it??
Old Sep 30, 2010 | 06:01 AM
Lance
I glass bead blasted the parts first.
I measured out some of the plating chemical and some distilled water into a stainless steel pot. I then placed the pot on a table top electric burner and brought the solution to 180 to 200 deg. I submerged the parts into the solution and about 15 minutes later you get what was in the photo above.
I was shocked how easy it was to do.
Old Sep 30, 2010 | 10:35 AM
I'm showing "image or video has been moved or deleted" on my screen instead of photo links.
Old Sep 30, 2010 | 11:30 AM
Lance
Sorry, I do not know how that happend, all I did was add some more photos and edit the folder name, and the Photo Bucket links were lost
I have now restored the photo links though.
Old Oct 11, 2010 | 08:00 AM
Lance
Some before and after phosphate plating photos of the hood latch that bolts to the bottom of the hood.
Before
Some signs of original GM gray phosphate plating!
After bead blasting and re-phosphate plating!
Also note the re-plated original circle "ER" marked bolts.
Old Oct 11, 2010 | 08:45 AM
6inarow's Avatar
Nice job on the phosphate plating. Did you buy the pint or quart size from Palmetto? Have you used much of the chemicals so far? You purchased both the zinc and manganese, have these parts been treated with the manganese? And finally, once you mix them up are you able to use the solution over or is it a one shot deal? This is exactly what I want to do for a number of parts and I really appreciate you putting these pics up for us. Looks great Lance.
Old Oct 11, 2010 | 09:51 AM
Lance
I bought a quart of each. I have did alot of small parts so far, and only used a small amount of the chemical. After each use, I filter the chemical thru a coffee filter and back into a plastic jug.
That hood latch was done with some chemical that had been used four times, and it still did a great job plating.
Old Oct 11, 2010 | 10:09 AM
TK-65's Avatar
Looks great. A company near me did one for me. I had to remove all the springs because the solution makes them very brittle.
I ended up trading mine for an NOS piece. A total black phosphate latch is not correct. These originally had gold cad plated rivets and latch mechanism.
Old Oct 11, 2010 | 10:27 AM
The first part I did was the hood latch on my '70 442. I was very pleased with the ease of use, and the final results. So.... I thought that I would share some before and after photos.
Impressive. You should consider going into business for yourself. I'm sure there's some coin to be made doing this.
oldspackrat
Sep 13, 2020 05:23 PM
frmula505
Dec 2, 2011 08:38 PM
georgiaboy697
Jul 2, 2010 09:23 PM
Lady72nRob71
May 9, 2009 06:25 AM
Cutlass69S
Oct 22, 2008 07:57 AM
