Outside Air Ind VS Rain
Old Jul 28, 2012 | 07:43 PM
Benton Quest's Avatar
No Dr. but play 1 on TV
Hi All,
Still thinking through my new car.
I plan to use this as a half time driver. Therefore I will get caught in the rain at some point.
How bad is driving in the rain when you have the OAI?
Opinions please.
Old Jul 28, 2012 | 08:06 PM
2blu442's Avatar
The factory 70-72 OAI bottom had I believe 5 small holes drilled in it to drain water. I drove a 1971 with OAI for about 10 years without drain holes and never had a problem. That was in Oregon, but depending on what part of the country your in that may or may not be an issue. During high school I lived near Tampa Florida for a couple years and remember the summer rain storms. I've kiddingly said you could be three steps from the door when the first drop hits but before you can get inside you'll be soaked to the skin! If you drive in tropical storms like that you may need drain holes
John
Old Jul 28, 2012 | 08:53 PM
allyolds68's Avatar
Don't tell your insurance company you may be driving it to work
Old Jul 29, 2012 | 02:39 AM
rustyroger's Avatar
'87 Delta 88 Royale
I don't understand, what is OAI?.
Roger.
Old Jul 29, 2012 | 03:52 AM
jensenracing77's Avatar
to add to what john said, the plastic top also has provisions to address this. what little water gets that far down the hood will mostly land on the plastic top. the top is made to run water down to the edges and then runs it all to the back. the back of the top has a drain hole on it that drains right on top of the distributor cap. it is a bad place to drain but is ok if you add a short hose to run the water down behind the distributor. any water that gets past the OAI flapper wil get out the holes that John is talking about. if you don't run the original setup the water will run on top of the engine.
Old Jul 29, 2012 | 03:54 AM
Roger.
OAI = outside air induction...Oldsmobile's term
many people call it ram air but that is Pontiac's term
Old Jul 29, 2012 | 03:58 AM
GM did not design its air induction system so that the car could only be used when it was sunny.
Old Jul 29, 2012 | 06:34 AM
Originally Posted by joesw31
Yep, I got cought in a strom with my 71 with OAI and I had to dry out the distributor cap to get the car running again.
X2... i was in high school and that happened to me one time. after that i always had the hose on it.
Old Jul 29, 2012 | 09:59 AM
69ho aurora's Avatar
The issue is when NOT using the car!
The 5 holes in the air cleaner base were an afterthought they learned the hard way after releasing the '69 H/O. Without them, the air cleaner base would fill up with water WHEN PARKED and the flapper door is sitting open (due to no engine vacuum and the seams around the scoop that the 70-2 don't have to worry about). The water would then drain into the carb. Turn over the engine with water in a cylinder or two and bend a rod (happened to me with an aftermarket air cleaner on mine before finding the proper one).
Olds put out a dealer service bulletin for the 69 H/O to drill the 5 holes in the base. I gather they had to warranty some engines before learning this lesson the hard way.
Old Jul 30, 2012 | 07:33 AM
rustyroger's Avatar
'87 Delta 88 Royale
Thank you, I know a little more than I did yesterday.
Roger.
Icey1966
Apr 28, 2015 06:57 PM
Rickman48
Jun 28, 2012 03:52 PM
tim72
Jun 11, 2009 09:14 PM
bear71
Mar 27, 2007 08:59 PM
