Opinion on 1966 442 rear 1/4 emblem placement
Old Apr 21, 2009 | 04:31 AM
aliensatemybuick's Avatar
"me somebody" site member
Any opinions on the placement of the emblems on the rear quarters of the car below? They are clearly placed lower down than I have seen on other cars. What would you conclude from this:
1. Clone?
2. Located improperly after replaced quarters?
3. It IS correct location for some cars (depending on where built?!)
3. Difficult to tell without more info?
Old Apr 21, 2009 | 04:53 AM
wmachine's Avatar
Trying to remember member
Way off, not even close.
1. Possible, Lansing built? (check cowl data plate)
2. Possible, or even after paint if the original holes were filled in. Sloppy work regardless.
3. Absolutely not.
4. Absolutely not. Its wrong, just a question of why.
Old Jul 24, 2012 | 10:27 AM
RAMBOW's Avatar
Ben
Could anyone provide some accurate dimensions on the placement of these quarter emblem?
I have lots of pics of cars w/ correct placement, I'm just guessing w/o measurements.
If anyone can help out, Preferably I'd like measurements from rear bodyline edge (bumper crease edge) to rear of emblem, and the lower bodyline edge (above trim piece) to bottom of the emblem.
Thanks-
Ben
Old Jul 24, 2012 | 10:13 PM
Run to Rund's Avatar
Wrong, wrong, wrong, wrong. FWIW, the F85 emblem used exactly the same hole spacing and placement as the 442 emblem on the quarters.
Old Jul 25, 2012 | 04:37 AM
rocketraider's Avatar
Oldsdruid
These guys are down in Atlanta with another facility in Charlotte. After a skirmish with them on a 67 Thunderbird a couple years back, my opinion is that you should be very careful dealing with them. They have pretty stuff, but not always on the up and up. On their website they come off as knowledgeable about the cars they're selling, but when pressed, it's obvious a lot of their knowledge comes from the internet.
Old Jul 25, 2012 | 05:29 AM
TripDeuces's Avatar
They need to fix that trunk line gap too
Old Jul 25, 2012 | 07:26 AM
RandyS's Avatar
Is that Bronze a stock color on a 66?
Old Jul 25, 2012 | 09:13 AM
RAMBOW's Avatar
Ben
Thanks-
Ben
I made up drill template for the staggered emblem holes last night- But i'm still guessing on exact placement of the emblem on the quarter. Distance forward from the rear & distance up from the bodyline crease.
Would really appreciate it if someone could walk out to their car with a tape measure and give me a couple locating dimentions before i start drilling...
Thanks-
Ben
Old Jul 25, 2012 | 11:34 AM
RandyS's Avatar
Here ya go.....
From the rearmost point on the Quater Panel - 1st hole is 8 3/4" toward front of car. 2nd hole is 2 3/4" further forward.
From the top of the QP trim piece, Rearmost hole is 3 1/2" above, forward hole is 3" above.
Hope this helps!
Old Jul 26, 2012 | 12:09 AM
RAMBOW's Avatar
Ben
Perfect! Thanks Randy- exactly what i needed!
Old Jul 26, 2012 | 09:26 AM
Oldsdruid
Yes. Autumn Bronze code M, 1966 only color.
Also used by Chevrolet as Aztec Bronze, Buick as Riviera Red (Riv-only), and not offered on Pontiac. Cadillac had an Emberglow Firemist that was similar, but different.
May be the lighting but this car looks a little light from what I'm used to seeing as Autumn Bronze.
Old Jul 26, 2012 | 10:53 AM
Nice to see that someone realized why you were resurrecting this old thread!
Old Jul 26, 2012 | 10:56 AM
So who is wrong X4? A question can't be wrong, and I see no answer prior to your post that is wrong.
What IS wrong is I had TWO option 3s (and only the first one can be answered in the negative for certain).
Old Jul 26, 2012 | 02:27 PM
Just a case of over-exuberance about the placement of the emblem, lol. I had never seen one there!
Old Jul 29, 2012 | 11:06 PM
RAMBOW's Avatar
Ben
Does this look right?
Cutting holes for fender scoops will be next...
Old Jul 30, 2012 | 10:13 AM
It should be about 1" higher up.
Old Jul 30, 2012 | 10:36 AM
RAMBOW's Avatar
Ben
Since you didn't post locating dimensions last week when I asked, you aren't allowed to give negative feedback this week after holes have been drilled
Randy's dims were close, but when i mocked it up, they wound up being slightly crooked and the holes were a hair too close together for the studs- so I modified to my liking & fit. If its not 100% perfect, I'll still sleep tonight. Its a clone/tribute anyway
Honestly, yours still looks pretty close to how mine turned out. If mines off, its only by 1/4 or so. My bumpers up a little tighter to the upper bodyline than yours is, might affect the way it appears.
1" higher on mine would have it edging above the level of the bumper, and thats way too high.
Old Jul 30, 2012 | 01:09 PM
RandyS's Avatar
Looks good to me. (but then, I guess it would) Took the dimensions off of my true 442. I think the pics may be a bit deceiving due to the color and shading of the darker car, but IMO they look to be in about the same location on both cars.......
Old Jul 30, 2012 | 06:27 PM
I couldn't post dimensions last week since both of my 66s are 580 miles away.
Old Jul 30, 2012 | 06:55 PM
RAMBOW's Avatar
Ben
Must mean its time for a 3rd!
Old Jul 30, 2012 | 07:24 PM
ent72olds's Avatar
Registered Luser
So I'm guessing the location wouldn't be in the '66 Body Service Manual?
LIMEGREEN71
Sep 30, 2015 11:56 AM
66cutlass
Nov 6, 2012 08:20 AM
toro455
Care and Appearance
Apr 21, 2011 09:18 PM
LIMEGREEN71
Jun 5, 2010 03:42 AM
rsandhoff
Oct 22, 2008 07:14 PM
