Ongoing Saga of 65 442
Old Nov 5, 2013 | 08:16 AM
HonestDave's Avatar
Finally got to roughing in my trunk pieces. Really need to get this thing on the road again !!
Should have 30 amp electrical circuit by noon tomorrow, maybe start some welding next week. A friend is going to come by and help me get set up. Be nice not to see the road through the trunk floor.
Old Nov 5, 2013 | 08:23 AM
stan 65 cutlass's Avatar
thats gonna be a breeze once you start frying some paint
Old Nov 5, 2013 | 08:33 AM
oldstata's Avatar
Justin
Just a bit of my advise I spot welded one side with the center section fitted then installed the last end section double check your body mounts and gas tank trap mount I had to do one twice
Old Nov 5, 2013 | 08:51 AM
f-85's Avatar
Got a 65 here that is in need of a trunk pan as well. If you can post as many pics as possible that would be helpful! Rust came in thru the back glass, im tired of looking past the glass thru the trunk and on the ground!
Old Nov 5, 2013 | 09:34 AM
HonestDave's Avatar
Thanks Justin,
Will take it under advisement. I might even rough it in with sheet metal screws to start. Cosidering I don't even know quite how to hook the hose on the welder, I'm certain this will be quite an odysee !!
Think I'll watch the half hour VHS that came with the welder. It's been sitting for years in it's box. Hope it even works.
Old Nov 5, 2013 | 09:36 AM
HonestDave's Avatar
I'll try to stay somewhat current with my pictures. I don't exactly move at a torrid pace, though.
Old Nov 5, 2013 | 09:54 AM
oldstata's Avatar
Justin
Save assemble with sheet metal screws then welds that what I did can't remember if you subscribed to by build thread but there is a ton of pics I set everything up and a friend adjusted and welded everything up
Your not having fun tell you grind the welds !!
A hint if you have your grinder pad and cut it like a stop sign
Helps keep it from snagging and if you use old pads save money
HonestDave
Body work
45
Jun 18, 2014 06:23 AM
HonestDave
Apr 24, 2014 04:44 AM
HonestDave
Body work
Feb 15, 2014 04:18 PM
HonestDave
Sep 19, 2013 04:58 AM
HonestDave
Nov 12, 2012 04:25 PM
