Need measurements on original-type non-OIA Air cleaner for '69 Olds 442
Old Feb 7, 2013 | 05:13 AM
razziz's Avatar
Needing an original-type non-OIA Air cleaner for my '69 Olds 442. However, in order to make sure I get the right one, could somebody who knows they have the correct original equipment send me some measurements? Outside top diameter of air cleaner pan, full height of air cleaner pan, length of intake spout, distance on spout to center of air regulator, height and width of spout opening, etc.?
I believe these had only one intake and were painted red. Where can I get the correct red paint (preferably in a spray can)? And the correct emblem (was it a decal or an aluminum circle)? A photo of correct emblem would really help.
Very appreciated.
Rick
Old Feb 7, 2013 | 10:10 AM
rcorrigan5's Avatar
Randy C.
For '69, the emblem was a decal. The decal, and the correct color paint, can be obtained from Fusick (www.fusick.com). I believe the part number for the decal is DC39 (you need to check to make sure) and the part number for the spray can red paint is AF150S.
I've got some other things going today but I'll take measurements of my '69 air filter tonight and send them.
Randy C.
Old Feb 7, 2013 | 10:33 AM
Paladin31's Avatar
Excuse the butt-in, but Randy could you email me those dimensions and/or pic's as well? Please & Thank you! Brett
Paladin31@msn.com
Old Feb 7, 2013 | 12:21 PM
razziz's Avatar
Randy C.
Randy:
Thanks! Look forward to getting the photos and measurements.
Old Feb 7, 2013 | 12:22 PM
Paladin31's Avatar
Thank you too Randy. Brett
Old Feb 7, 2013 | 12:28 PM
razziz's Avatar
Originally Posted by razziz
Randy:
And Randy, you are right on the part numbers (just called Fusick).
Rick
Old Feb 7, 2013 | 04:51 PM
501Paratrooper's Avatar
https://classicoldsmobile.com/forums...r-cleaner.html
Here is a picture of mine, with the rattle can red from super cars unlimited. If you don't get the measurements I can get them for you this weekend.
Old Feb 7, 2013 | 05:09 PM
razziz's Avatar
Paratrooper
Thanks!
Rick
Old Feb 7, 2013 | 08:13 PM
rcorrigan5's Avatar
Randy C.
Here's the measurements I got. I took a bunch of pictures so I'll follow on with extra posts to show all the pictures. My '69 is the standard issue 400 engine, no OAI, the car does have A/C.
Outside top diameter of air cleaner pan: 16 9/16"
Full height of air cleaner pan: 2 1/2 "
Length of intake spout taken on center top: 8 7/8""
Length of snout taken on the side: 9 1/2"
Distance on spout to center of air regulator (on top): 6 5/8"
Distance on spout to center of air regulator opening (on bottom): 6"
Height of spout opening: 2 3/8"
Width of spout opening: 3 3/4" to 3 13/16" (hard to tell here; mine is a little bent!)
Air cleaner lid: 16 7/8" diameter
I'll start adding pictures here.
Randy C.
Old Feb 7, 2013 | 08:17 PM
rcorrigan5's Avatar
Randy C.
More pictures. Just a word to advise: Those aren't my fingernails!
Randy C.
Old Feb 7, 2013 | 08:19 PM
rcorrigan5's Avatar
Randy C.
And the last of the pictures.
Randy C.
Old Feb 7, 2013 | 08:21 PM
Paladin31's Avatar
Thank you for the pics and dimensions
Red really is your color ....
Brett
Old Feb 7, 2013 | 08:37 PM
rcorrigan5's Avatar
Randy C.
I was looking at the measurement on the bottom of the snout to the center of the air regulator opening wrong. It looks more like 5 13/16" to the center of the opening, rather than the 6" I had previously indicated.
Randy C.
Old Feb 8, 2013 | 03:04 AM
razziz's Avatar
Wow! Great photos. Very helpful to many, because the 69 Olds 442 Air cleaner was only produced in that exact form only in that year.
Thanks Randy!
Rick
Old Feb 8, 2013 | 04:38 AM
wmachine's Avatar
Trying to remember member
A minor FYI here: That air cleaner was not exclusive to the 442. The "Highway Patrol" L32 got the same air cleaner with the only difference being the decal.
Old Feb 8, 2013 | 07:13 AM
razziz's Avatar
Wmachine:
Thanks! Can you send a photo including the spout (name?).
R. Azziz
Old Feb 8, 2013 | 07:50 AM
wmachine's Avatar
Wmachine:
R. Azziz
It is no different than what Randy posted.
Old Feb 8, 2013 | 07:47 PM
razziz's Avatar
Very appreciated.
Rick
Old Feb 8, 2013 | 08:04 PM
Octania's Avatar
Nice work guys
before the Crash of 2012 [my computer] I had handy photos showing the difference in snouts between '69 Cutlass and 442. Width of the base where it meets the housing is pronounced.
If your factory inked info is still present, the part number and 2-letter code can be found there, which pegs the application. I believe "OS" is one of the '69 442 air cleaners.
aha
Old Feb 8, 2013 | 08:17 PM
razziz's Avatar
Originally Posted by Octania
Nice work guys
Thanks! Yes, the ones that I have seen do have an OS two-letter code
Rick
Old Feb 9, 2013 | 11:14 AM
wmachine's Avatar
The search can be broadened out to other non-442 origins too. The '69 Inspector's Manual reveals that Some Vistas and Deltas have them. Vistas with the 400 (L31) had them. All Delta models with the 390 hp L32 455 had them, too, regardless of whether or not they were Cop cars. The only differences are the labels.
Old Feb 9, 2013 | 11:41 AM
Octania's Avatar
Which then begs the question:
"What air cleaner does that '67 Cop Car A-body seen elsewhere on CO have?"
Old Feb 9, 2013 | 12:11 PM
wmachine's Avatar
Should be the L77 engine which is the same as the L78 442 engine except for plugs and air cleaner label.
Old Feb 11, 2013 | 01:22 PM
rcorrigan5's Avatar
Randy C.
I have an "OR" air cleaner in my spare parts that, on first glance, looks just like the "OS" air cleaner mentioned above, probably because the color (red) is the same. But that "OR" air cleaner, upon just a little closer inspection, is quite different! I believe the "OR" air cleaner has some 350 and 455 applications, but not used on the 400 engine.
Randy C.
Old Feb 11, 2013 | 05:44 PM
wmachine's Avatar
Randy C.
Correct. "OR" is "the other" much more common red high compression air cleaner. Noticeably narrower snorkel where it meets the air cleaner body.
In '69 (and most of the '60s) the high compression air cleaners were red and the low compression were black.
Old Feb 11, 2013 | 05:58 PM
Paladin31's Avatar
Randy, does your OR look like this? note the inlet throat collar..
PS.. the decal wasn't me..
Old Feb 11, 2013 | 06:48 PM
rcorrigan5's Avatar
Randy C.
My "OR" doesn't quite look like your air cleaner. I've attached pictures so you can see how mine looks. I've looked around and I'm pretty sure this "OR" is for a '69; I didn't see 6484803 listed for '68 and I don't have any listings for '70. But what you see below is what I have. The lid is from somewhere else - the center chrome piece doesn't even fit as it should. And, per your comment, "...the decal wasn't mine..." either!
Randy C.
Old Feb 11, 2013 | 06:54 PM
Paladin31's Avatar
lol. I am pretty sure mine is a 68, as it has a square breather hole., def not a 442 though...your decal looks much more better OE...
Old Feb 12, 2013 | 02:56 AM
razziz's Avatar
So would an air cleaner with #OS 64848?4 (can't make all the numbers out - see photos attached) be correct for a 69 442?
Rick
Old Feb 12, 2013 | 05:07 AM
wmachine's Avatar
Right, a '68. Looks like the OE found on high compression 4-bbls (OC on high compression 2-bbl 455s.)
OG is the 442 aircleaner, also found on L77 (cop car) A-bodies, 400 ci Vistas, and the L74 and L76 equipped 88s.
Old Feb 12, 2013 | 05:20 AM
  #31
wmachine's Avatar
Rick
Yes.
Old Feb 12, 2013 | 05:41 AM
  #32
Paladin31's Avatar
Thank you for the confirmation Kurt.
Old Feb 12, 2013 | 07:55 PM
  #33
razziz's Avatar
Yes.
Rick
Old Feb 23, 2013 | 06:39 PM
  #34
Octania's Avatar
6484803
CLEANER, AIR CLEANER ASM- Code "OR"
1969 F-85 Cutlass, Full Size Olds 455 4BBL
razziz
Feb 7, 2013 11:13 AM
69CutlassAlex
Dec 2, 2011 08:01 AM
425dude
May 31, 2010 12:42 PM
