Need advice on this 442
I'm a Chevelle guy looking for another project, I may have found one: http://buffalo.craigslist.org/cto/5104731340.html
What do I need to be on the lookout for with this car? What I know so far is that the VIN needs to start with a 344 to be a true 442, and the engine VIN stamping is on a pad on the drivers side in front of the exhaust manifold? I'm not sure exactly where to look.
That car is a hard top so the VIN should start out as 34487. The stamping is on the front most upper corner of the block on the drivers side where it meets the head. It's not the entire VIN just the last digits after the 34487.
Thanks. Another question, what kind of aftermarket sheet metal is available for these cars, and how is the quality? I took a quick look at: http://www.autometaldirect.com/body-...ents-c-23.html and https://www.shermanparts.com/ecat/ba...lass&year=1971
Doesn't look like there is available some of the sheet metal I may need. I don't see any good source for full qtr panels. (I try to stay away from Goodmark and OPGI stuff, Taiwan garbage).
If your in ny you may be better served going after that v code 72 that's discussed in another thread for a few k more you get what would appear to be a much better condition car and a 4 speed as well.
http://www.ebay.com/itm/121692673523...3D863733297281
I would hope to get the car I linked at around $8500. It really depends on how bad the rust is when I go look at it today. I emailed that guy with the V code car, it's not too far from me, I'll try to take a look at it.
Personally, I'd run screaming from any car in Buffalo. There WILL be rust.
I don't specifically need a 442, but I've always thought they were cool so they are on the table. And yes, I'd not be interested in his repo bumpers.
The owner said he sandblasted the bottom of this car and sprayed liquid bedliner on it I'm sure it's a mess.
Well, that's where I live man... I have been looking for ~4 months for a driver because my Chevelle restoration (https://imgur.com/a/v2PHi#0) is dragging and I need a muscle car fix. You're right, they all have rust except for the ones not from the area, found a really sweet 72 Skylark close by that came form AZ, absolutely no rust, but seller wants a fortune...
Not that I've ever listened to my own advice, however...
I have a lot of ppl on a lot of forums telling me that, it does make sense. But finding someone you can trust to inspect the car for you is the trick. I can't afford to fly all over the country for find a car.
btw, the AZ Skylark in Buffalo: http://buffalo.craigslist.org/cto/5093226382.html
So there are rust free cars in Buffalo, but it just takes a while to find them. The 66 SS 396 I bought here was from California, spent most of its life in Florida etc.
Edit: too late on that V code, already sold. Jeez a day late on deals here what's going on?
There's plenty of cars from AZ, CA, etc throughout the US. Sure, they cost more. But as Joe pointed out, in the long run they cost less.
