My 71 442 tach is way too fast
Stock tach?
There is a silver "cover" on the back. If you remove it you will find a potentiometer. That will allow you to adjust the tach. Make sure to use a known working diagnostic tach (tach & dwell meter for example) to set it.
The Olds Wiki has a section with calibration, basically it's what svnt442 said.
http://www.oldsmobilewiki.com/index....ak_Tic_Toc_Tac
EightballZ
August 24th, 2015 04:56 AM
ATrain1
Non-Olds Engines
June 29th, 2012 12:58 PM
80delta350
February 21st, 2011 04:34 PM
