Mismatched air filter
Old Feb 11, 2017 | 11:09 AM
tinytank's Avatar
Question Mismatched air filter
Can someone explain to me what is going on here? This is a 455 in a 1970 442 Convertible. It seems I either have the wrong air filter, the wrong distributor, or I am missing something very obvious. There's not much use having an actual filter when you have that much of a gap between the carb and the housing of the air filter.
Thanks for reading and have a great weekend / Eddy
Old Feb 11, 2017 | 11:36 AM
That is a HEI distributor that wasn't installed by the factory until 1975, so you have a mismatch between the air cleaner lower housing and the distributor.
I have read that some folks have clearanced the air cleaner housing so it would fit. I have an aftermarket air cleaner so I don't have first-hand experience with that.
Old Feb 11, 2017 | 11:40 AM
tinytank's Avatar
Wow, that was fast! Thanks, Kenneth! I guess I'll McGuyver my way around it for now.
Old Feb 11, 2017 | 11:48 AM
You could look for a 75-up lower housing that has a factory "dent" for clearance but I don't know if the rest of the housing would be similar to a 70 442 setup (snorkel angle and size, PCV hose fitting, etc).
Old Feb 11, 2017 | 04:02 PM
Even though it wasn't factory installed, the stock air cleaner WILL just barely clear an HEI with STOCK cap and coil on a 455. The OP's problem is that Accel aftermarket coil on top of the HEI cap. The added thickness of the coil is the real problem. Lose it.
Old Feb 11, 2017 | 04:31 PM
stevengerard's Avatar
yes, don't mess with the air cleaner base - either change distributor like Joe said. A normal HEI will fit, or get an original distributor and put a petronix kit in it.
Old Feb 11, 2017 | 05:33 PM
The OP doesn't need to change the distributor, just the coil. The normal HEI coil cover looks like this.
Old Feb 12, 2017 | 06:37 AM
RetroRanger's Avatar
72 Olds CS
Adam UN= tru-blue 442 was selling an offset base air cleaner not to long ago those are made to clear the Hei as well
Old Feb 12, 2017 | 06:40 AM
Or he can put a small spacer between the carb and air cleaner.
Old Feb 12, 2017 | 06:43 AM
Since all 1970-72 442s have an O.A.I. hood these days, the spacer and/or the offset air cleaner will cause a problem with that.
Old Feb 13, 2017 | 03:15 PM
BlackGold's Avatar
Be aware that an HEI distributor most likely does not have an advance curve optimized for your engine. Spending a little time learning about this, or finding someone who already knows, might really wake up your engine.
Old Feb 13, 2017 | 04:51 PM
tru-blue 442's Avatar
Old School Olds
Still available if needed. Thanks Roger.
Old Feb 13, 2017 | 06:25 PM
Then there's always beat to fit, paint to match, if you have a crappy air cleaner.
76olds
Aug 26, 2016 08:56 AM
Octania
Apr 3, 2016 03:45 PM
GoldOlds
May 27, 2007 01:14 PM
