Its a real 442??
Old Jun 20, 2007 | 04:51 PM
442 Guatemala's Avatar
Question Its a real 442??
Hello Im restoring a 1966 olds 442 with 400 engine. Im triying to decode the VIN number, everithing match, but never says its a 442.
how to know if my car is a real 442? what are the characteristics of a 442?
thanks
Alex
Old Jun 20, 2007 | 08:17 PM
And it won't. Prior to 1968 the 442 package was only an option available on certain Cutlass and F-85 models. The 442 only got a unique VIN between 68 and 71.
By the way, what "matches"? Olds did not start putting VIN derivative stamps on the block, trans, and axle until 1968, so "numbers matching" is somewhat meaningless for a pre-68 Olds.
http://www.442.com/oldsfaq/of442.htm...Authentication (keep scrolling and you'll find a section with year-by-year info)
Old Jun 21, 2007 | 03:58 PM
matches
thanks for the information. when I said matching number I mean its a 1966 F-85. Other thing I cant find is if the VIN or ID plate says the engine size. mine has a 400 engine
Old Jun 23, 2007 | 06:39 AM
And again, it won't. Before 1972, there was nothing in the VIN or any ID plate that would indicate engine size.
Old Jun 25, 2007 | 08:56 PM
ReasonOne
Guest
Posts: n/a
GIve me a breakdown of the cowl tag, engine tag and transmission code and I can fill you in on what you might have.
Old Jul 12, 2007 | 08:18 AM
Chip's Avatar
where is the cowl tag located?
Old Jul 12, 2007 | 10:54 PM
Ranzan's Avatar
Getting There
The Cowl tag is located on the drivers side Firewall just beside your master cylinder
boyd_farmer00
Nov 5, 2013 08:12 PM
Nickyloves442s
Cars Wanted
Jun 11, 2013 09:18 AM
1956OldsDarrin
Jan 23, 2011 12:11 PM
woodie582
Jul 21, 2008 05:53 AM
