Hood insulation pad question
Old May 25, 2019 | 10:54 AM
jerry63's Avatar
Hello, which side of the hood insulation pad attaches to the underside of the hood, there is a smooth dark side and a rough fiberglass side to the pad, This is a 65 442, thanks.
Old May 25, 2019 | 11:15 AM
patshotrods's Avatar
Pat
Jerry,
The dark side goes towards the hood and the rough fiberglass grey side goes towards the engine. I am actually installing one on my car this weekend as well.
Old May 25, 2019 | 11:28 AM
jerry63's Avatar
Thanks Pat, I hope you have a great holiday.
Old Jun 4, 2019 | 10:17 AM
android 211's Avatar
Hood insulation
Maybe I bought the cheap stuff but I did that and wind from the fan blew a hole in the insulation. I think next time I put the hard side down.
Old Jun 4, 2019 | 06:33 PM
Pat
android 211,
Does your car have a fan shroud? Can you post some Pictures?
Please Advise...
Thanks,
Old Jun 5, 2019 | 04:25 AM
BlueCalais79's Avatar
I just installed one in my 79 Cutlass and I put the hard side down (exposed) I used round clip number 3977775. Got the pad from Fusick's, what I like about it is it has the holes already in it, no guesswork.
Old Jun 5, 2019 | 07:14 AM
jerry63's Avatar
Insulation
I installed it with the hard side facing the hood, I used the clips from Kusick, so far no problems.
Old Jun 6, 2019 | 04:09 PM
Iraq 69's Avatar
Hey pats hot rods,
where did you get your insulation kit and pins. I also have a 73 and need the whole works.
marc
Old Jun 6, 2019 | 07:16 PM
Pat
Marc,
1st off "Thank You" for your Service Sir! My dad was in Vietnam, he was a member of the "Big Red 1". I bought my Hood Pad on eBay thru The Parts Place and since I work for Advance Auto Parts I bought my Round Hood Pins there, you will need 13 of them for the install, everything went fine as I have put a lot of these on over the years although some times 4 hands are better than 2 when doing this job. I will take some Pictures of my install over the weekend and post then on the forum.
Thanks,
Old Jun 8, 2019 | 03:11 PM
Pat
Here is a Picture of my install, I just need to re-install my Under-Hood Lamp.
Old Jun 8, 2019 | 04:37 PM
Iraq 69's Avatar
Looks great. Thanks for the help and pics
Marc
Old Aug 26, 2019 | 06:37 PM
35tac's Avatar
Did you use any adhesive? How tough was it to install the pad without taking the hood off.
Wayne
Old Aug 26, 2019 | 07:32 PM
jaunty75's Avatar
Originally Posted by jerry63
I installed it with the hard side facing the hood.
I installed a new hood pad in my '78 Toronado, and I had no choice as to how it was oriented as it came with a cutout for the underhood light (lower right in the photo). Thus, the pad could be installed only one way, and that was with the hard side facing the engine. I always thought this made sense because the hard side protects the insulation from any fluids, dirt, etc. that might get onto it from the engine compartment.
I did use adhesive, which helped hold it in place while I pushed the clips into place.
Old Aug 26, 2019 | 07:52 PM
classicmuscle442's Avatar
Makes more sense with the hard side down, when the loose side surface gets dirty it's impossible to clean, next time will install hard side down.
Old Aug 27, 2019 | 05:53 AM
Billyaxe's Avatar
I’ve been to a lot of car shows lately and see many top notch restored cars that don’t have the insulation pad under the hood. What is it’s actual purpose of it and why are some people not using them? Thanks —Billy
Old Aug 27, 2019 | 06:56 AM
Pat
I did not use any adhesive. It was a little difficult to install it by myself but after I got a few of the round clips in it was fine.
Old Aug 27, 2019 | 02:01 PM
35tac's Avatar
Thanks for the information.
Wayne
Tiberian Fiend
May 17, 2018 07:49 PM
67Rocket
Paint
Aug 21, 2016 07:52 PM
jdana24
Dec 14, 2014 02:22 PM
BStone
Sep 17, 2012 08:38 PM
Gearhead442
Body work
Jun 5, 2012 08:10 PM
