header choices
Old Aug 20, 2016 | 08:05 AM
44blue's Avatar
header choices
hi. I guess this might be the right spot for a question that has probably been beaten to death- Header choices.
My car is 71 olds 442 with 455 and 4 speed, power steering.
1) whats the best street header available, who and how much?
2) What's a decent cheaper header, who and how much?
3) The 184.00 dollar "stainless" headers on amazon right now can't be real can they?
My concerns are such : fitment (remember , 4 speed), power steering/steering column clearance, lowness to ground speed bump (scrape), and , does center link have to thread through these?
I know its a lot of questions, any help will be appreciated,
neal
Old Aug 20, 2016 | 09:49 AM
You're right, it has. SEARCH is your friend.
https://classicoldsmobile.com/forums...***-455-a.html
https://classicoldsmobile.com/forums...6-headers.html
https://classicoldsmobile.com/forums...x-headers.html
https://classicoldsmobile.com/forums...aders-not.html
Old Aug 20, 2016 | 10:58 AM
I can't give much info on most of your questions, but for the one below, no.
Old Aug 20, 2016 | 06:40 PM
jfb's Avatar
jfb
doug thorleys 1 and 3/4. I had a set until I needed larger tubes. they fit excellent with a mini starter. the tubes on the drivers side give excellent clearance with the brake parts and lines also.
Old Aug 20, 2016 | 10:28 PM
z11375ss's Avatar
Senior Moment Member
If I could give some advice, I would go with the ball joint configuration offered by Flowmaster that turns your header flange into a modern ball/joint flange. No leaks, no gaskets, just pure awesome. I think they're a bit pricey though. I have run them on several cars and really like them.
https://www.summitracing.com/parts/flo-15925
Old Aug 21, 2016 | 08:17 PM
Run to Rund's Avatar
American Racing Headers
Old Aug 22, 2016 | 07:23 AM
Heddman also offers a ball/socket type collector.
nonhog
Dec 2, 2010 09:03 AM
Aceshigh
Feb 24, 2010 07:15 AM
nonhog
Feb 21, 2010 09:21 AM
procharged70cutlass
Dec 21, 2009 08:03 PM
ImWired
Dec 19, 2006 05:40 AM
