Glove box
Old Jan 26, 2014 | 03:48 PM
Dave Leonard's Avatar
Glove box
My 67 442 has a problem wit the lock on the door. Lock works fine but the whole assembly turnes as you lock or unlock it. Is there a clip missing
Old Jan 27, 2014 | 07:38 AM
Miles71's Avatar
https://classicoldsmobile.com/forums...ainer-nut.html
The escutcheon nut is loose.
there are many links on this forum on how to fix.
You need to remove the door.
Remove the tumbler and then tighten the nut.
Re-install the tumbler, etc.
Hope you have the key.
Old Jan 28, 2014 | 02:02 PM
Thanks. Ill try it.
Old Jan 28, 2014 | 02:47 PM
nicks1966's Avatar
the lock housing should have two tabs that go into slots in the glove box door, I have seen more than a few broken off. tightening the nut will help but if the tabs are gone it will move again.
rroth01
Aug 23, 2008 10:06 AM
kevinkpk
Nov 12, 2007 10:27 AM
kevinkpk
Nov 4, 2007 03:26 PM
The_Jeremiah
Sep 18, 2007 09:48 PM
CWINBLADGO
Jul 31, 2007 11:39 AM
