Four-row radiator in '67?
I'm in the final stages of rounding up the parts to get my '67 finished up this summer. I've got a 3-row radiator with a shroud now to cool my 455, and while I didn't have any problems with cooling when the car was last driven, I'm adding a ton of horsepower this time and want to make a pre-emptive strike by upgrading to a 4-row radiator.
So what parts will I need to locate? I'm sure I'd need the larger saddles, right? Where would I find these? Will I be able to continue using my factory shroud?
Keith
What diameter size is the shroud on your radiator? I want to put a shroud on my car but I have a 19inch fan on a 425 engine so the shroud from Supercars is too small. Was your shroud stock on your car? Would you mind sending me a picture of it? My Email is patcar@shaw.ca.
Pat
Pat
Another thing I did. The 66/67 rubber pads are held in place with rubber tabs pulled through a hole on each end of the saddle, so when the saddle is made wider the pad will no longer fit in the holes as before. I didn't like the way the saddle went down the front and rear of the tanks which is where the holes for the pads were located. I thought most cars had very little in that area, most are just slightly turned over the end of the tank where mine were a long way down. I decided they didn't need to be so long so I cut them off to resemble some other cars I have owned. Then I glued the rubber pads in with black weather strip adhesive just to hold them in place long enough to bolt it all in place. After bolting it all in place it is not going anywhere anyway. I also trimmed the sides/edges of the saddles on mine as I thought they were too big and I wanted them smaller. It all worked fine for me. If you want pictures I could post them.
Mike
Keith, I did pretty much the same thing as Mike to install a Summit aluminum radiator in my 442. I just drilled out the spot welds, cut the saddles (and pads) in half, then reattached them by plug welding through the drilled holes. Pop the pad halves back in and everything bolted right back up. The only hitch was that the petcock interfered with the frame rail, so I scooted the rad & mounts over a bit to the passenger side to get enough clearance.
Keith
Thanks for the pictures. The shroud I received from Supercars in Portland is not like your shroud at all. I am going to send it back.
Do you know where I could buy a correct shroud. Fusick stocks what appears to be the same one as Supercars. If I could find a used one that would be great, but to search up here would be futile. Any ideas??
Pat
Pat
Pat, take a look at The Parts Place part #CS1640T.
http://www.thepartsplaceinc.com
Thanks Copper128. Looks like the one I already have. After having looked more carefully at Keith's pictures, I may be able to make mine work. The factory manual doesn't show the brackets used to attach the shroud but Keith's pictures do so I'll have a go at it.
Thanks again.
Pat
Thanks again.
Pat
I don't know if it matters anymore, but I just did a 4 row in my 67 442 stock motor today. We drove it to Colorado from MN. and had to keep the speed down around 55 to keep the temp below 220F. I put a metal 4 row, a Delco thermal fan clutch (A/C car) a 160F thermostat and stock fan blade and shroud. Have yet to exceed 185F. Yes, I'm Pleased.
Indy_68_S
November 24th, 2010 07:52 PM
Wil Lopez
Ninety-Eight
August 29th, 2010 09:41 AM
