Floor heat dampness
Old Sep 24, 2012 | 10:36 AM
69'442's Avatar
Floor heat dampness
I bought a clear set of mats to keep my carpet clean in my 70 442. I notice after cruising around the passenger side front and back mats both steam up underneath. I never realized how much heat came up from the floor. I guess there is moisture in the carpet. I would hate to see the floors rot out from this moisture. I now remove the mats to air it out when I am not driving. I have original manifolds and 2 1/2 exhaust. I don't see it on the driver side. Is this common? Anyone else notice this?
Old Sep 24, 2012 | 10:41 AM
Sounds to me there is some moiter getting into your car either by a hole in the floor, or window and/or door seals.
Old Sep 24, 2012 | 10:56 AM
Lady72nRob71's Avatar
moiter?
Pull the carpet away from the heater box on the passenger side to check for signs that the heater core is leaking.
Has the car been recently washed or has sat in the rain?
Old Sep 24, 2012 | 11:27 AM
69'442's Avatar
Car has never been washed. Just waxed. Garaged and has never seen rain or snow. Floors were redone and painted and new carpet. I checked under the carpet by the heater and it looks ok. I'm not saying there was alot of moisture. Just steam on the underside of the matts. Carpet feels dry. Could be humidity in the carpet.
Old Sep 24, 2012 | 11:38 AM
bccan's Avatar
Any coolant smell? Heater core sure seems like it would be the only moisture that could find it's way into/under carpet if car never gets wet.
Old Sep 24, 2012 | 12:29 PM
You must be in a hi humidity area for the mats to fog then. I don't think it's a heater core as the coolant should not make to the backseat area.
Old Sep 24, 2012 | 01:04 PM
Intragration's Avatar
If it's not coolant, then it's just condensation. There's a lot of moisture in the air. When there are temperature differentials, you get condensation. You probably have some moister air trapped under the mats, and now that it's getting colder the moisture is coming out. A can of Damp Rid should help.
Old Sep 24, 2012 | 01:13 PM
Depends how fast he accellerates!
Old Sep 24, 2012 | 01:59 PM
Mikes65's Avatar
Check the heater core good! Look for a drip or any moisture at the bottom of the heater box. The core can seep and drip a little before it is noticed--ask how I know--
jon1957
Body work
16
Nov 2, 2018 09:10 PM
Dream Whip
Aug 9, 2016 02:59 PM
jstrits
Feb 7, 2016 11:33 AM
smcurro
Paint
Jan 29, 2012 02:31 PM
bjtstarfire
Nov 13, 2008 02:04 PM
