Flat washer AND lock bracket for 1967 Exhaust Manifold?
Old Aug 10, 2023 | 08:07 PM
mwbailey's Avatar
Enjoyed reading several posts about exhaust manifolds. I am currently installing manifolds on my '67 and have a simple/stupid(?) question or two. Since Fusick supplies manifold bolts WITH flat washers AND sells exhaust manifold lock brackets, where do you put the flat washer with respect to the lock bracket? Looks like on my "original" '67 442, it's bolt head, bracket, flat washer, manifold; but there's a lot of rust and corrosion down there!
I was curious about the 25 ft-lb torque spec and can see why a lock bracket might be needed at the low torque! Makes sense, I guess. So, just to make sure, do you punch up a corner of the extended "shoulder" on the lock bracket?
I'm using anti-seize on bolt threads and will use a Fel Pro gasket since it was in the kit. Very interesting that gaskets were not used when manufactured.
Thanks for your thoughts.
brianbeez67
Mar 11, 2022 01:15 PM
AtomicT
Jun 15, 2017 07:52 AM
Oldssupreme
Aug 1, 2016 09:39 AM
vmathy
May 29, 2011 10:57 PM
hinz57
Oct 8, 2009 07:09 AM
