fender antenna install?
Old Dec 24, 2017 | 09:43 AM
ben442's Avatar
68 442 convertible
What do I need to remove to install a new fender antenna ( cable, mast and fastening hardware )
Does the fender need to come off?
Merry Christmas all...
Ben
Old Dec 24, 2017 | 09:52 AM
Its a very easy install, just an adjustable wrench. Are you replacing an existing one?
Old Dec 24, 2017 | 10:06 AM
ben442's Avatar
I have a new one from the parts place, hole in the fender, no current antenna in place.
Old Dec 24, 2017 | 10:20 AM
I don't remember where the antenna cable feeds through. Sometimes you need a flexible wire taped to the cable to feed through the hole in the body. There is a folding base that is attached to the bottom of the mast that tightens against the underside of the fender when you tighten the mounting nut. Route the cable to the radio and plug it in.
Old Dec 24, 2017 | 11:40 AM
dream66's Avatar
Cory
The cable on A-body cars typically routs from below the fender into the top of the cowl cavity and penetrates through the top of the firewall with a seal/grommet.
66 chevelle pics: (no firewall penetration here because the car originally had a rear antenna)
Old Dec 24, 2017 | 01:38 PM
rcorrigan5's Avatar
Randy C.
This is a page out of the '69 assembly manual but it's exactly the same as for the '68 model year. Although there is a bit of a difficulty factor, you should be able to install the antenna with the fender on the car.
Randy C.
Old Dec 24, 2017 | 01:42 PM
ben442's Avatar
Thanks Randy, I think I've got the same page in my 68 manual.
curtis mayfield
Feb 21, 2023 07:13 AM
at3reg98
Jul 22, 2012 06:33 AM
scr8p
Jan 23, 2012 10:18 AM
Del70
Jul 16, 2011 09:59 AM
Jonb442
Body work
Feb 15, 2009 05:15 PM
