Engine stamp decode info
Old Sep 12, 2022 | 05:26 PM
ericisback's Avatar
Is this engine date stamp decode info correct? Thanks!!!
Old Sep 12, 2022 | 07:31 PM
66SportCoupe's Avatar
Yes that is the date code of casting
Old Sep 13, 2022 | 05:39 AM
First of all, that's not a "stamp". Stamped numbers are inset and applied after the part is cast. The VIN derivative is a stamp. These are raised casting numbers that are integral with the casting.
Second, despite what you may read on the interwebs, the large raised "3" is a mold number and has no direct relationship to the year or any other date. Below is a dealer technical bulletin that clearly identifies this as the mold number.
Third, the small number is the day of the year. The VIN derivative stamp will tell you the model year, which lets you figure out the day of WHICH year that julian date number refers to.
Old Sep 13, 2022 | 07:03 AM
ericisback's Avatar
Thank you for the mold number info. I was aware of the VIN derivative stamp.
Just a friendly FYI, I did not get the info from the interwebs. The information I used is from page 28 of “The Good Old Days, Oldsmobile 1964 thru 1972 A bodies” by Michael J. Siedlik.
From page 29:
Your information is good to know.
Old Sep 13, 2022 | 11:05 AM
Be even more suspicious of a book that gets it's info from the old Oldsmobile FAQs on line. That's just sheer laziness (and theft) on the part of whoever published that. Here's an FYI back to you: Don't trust third party documents like that. Get your info from factory literature if at all possible. Most of what I've read (both in books and online) is incorrect, and frequently is just copying bad information that someone else wrote.
Old Sep 13, 2022 | 03:11 PM
Rocketguy's Avatar
I've also heard it called the "core box" number.
The oldest rumor of this number I remember is that it revealed the nickel content of the iron
I believe there is a larger version of it on the back of the block behind the flywheel.
Joe P is right again; always look for your information in factory literature.
Old Sep 13, 2022 | 06:49 PM
The ludicrous part about the "F number" related to nickel content myth is that all 1964-up Olds motors have an "F number" on the back, but the nickel content link only applies to 455 blocks. WTF? This one long predates the interwebs, so we can't blame it for this. Also the "headers don't fit Supremes" myth.
Oldsmaniac
Apr 24, 2020 01:01 PM
oldsmoguy
Nov 18, 2013 09:37 AM
sealw98
Oct 15, 2009 08:33 AM
captjim
Jul 15, 2009 08:53 AM
toplessrocket
Mar 9, 2008 07:22 PM
