Cowl tag help
Old July 15th, 2010 | 08:53 AM
Thomas Simcich's Avatar
Cowl tag help
Could use some help with decoding the data plate or cowl tag mounted on firewall! Thanks to all Tom Simcich
Old July 15th, 2010 | 09:17 AM
stevengerard's Avatar
post a pic or what it has on it, many folks can tell you what it means but we need to see it
Old July 15th, 2010 | 09:29 AM
Cowl tag
ST 66-33817 Lan31266 BODY
TR 080-C J-J PAINT
W 2L
5V
This is for a 1966 442. Car has tripower. Currently on Ebay.
Old July 15th, 2010 | 11:05 AM
Run to Rund's Avatar
ST = style
66 = model year
33817 = Olds 2 door hardtop
Lan = Lansing build
31266 = Fisher Body sequence number
TR = trim
080-C = black vinyl custom sport seat (bench with center fold down armrest)
J-J paint = forest mist
W= tinted glass windshield only, opton A02
2L= body option group 2, L=floor shift 4-speed (M20 or M21)
5V=body option group 5, V=442 trim
You did not tell us the codes at the top which give production date.
I assume this is the car, which you started another thread about recently:
http://cgi.ebay.com/ebaymotors/Oldsm...5fTrucks#v4-45
Next time, we can help easier if you give us the full information that you have, please.
07C means produced third week of July. Since this is after the announcement date of December 1966, the car could have been produced as L69 (Tri Carb 442, vs. L78, 4 barrel 442). In your other thread we already discussed the correct and incorrect parts on the car as far as we could tell from the ebay photo.
Old July 16th, 2010 | 09:02 AM
Vin #
Should the number stamped on the pad of the head match the sequence number on the VIN on a 1966 442?
Old July 16th, 2010 | 10:23 AM
Nope. It's the engine unit number, assigned when the engine is built - before the car VIN sequence number is assigned. The Protect-O-Plate is the Rosetta Stone that ties the engine and trans unit numbers to the VIN. The VIN derivative stamping on the engine block didn't start until the 1968 model year.
Old August 22nd, 2010 | 07:11 PM
66fourspeed's Avatar
Is there an option code on the cowl plate for a 66 cutlass 442 if it is a L69 or W30?
Old August 22nd, 2010 | 07:49 PM
Nope.
duckblaster67
November 24th, 2020 04:01 PM
NorCalAndy
February 24th, 2009 07:43 PM
mr-tom
June 25th, 2007 09:51 PM
DesertToro
January 16th, 2007 08:10 PM
Mr. King
January 14th, 2007 08:47 PM
Quick Reply: Cowl tag help
