Any experience with this header?
Old Sep 4, 2011 | 10:49 AM
joepenoso's Avatar
Question Any experience with this header?
Any experience with this stainless header???
http://www.ebay.ca/itm/OLDSMOBILE-42...item2a139c9a06
Old Sep 4, 2011 | 11:11 AM
TripDeuces's Avatar
Do the exhaust ports look small to anyone else?
Old Sep 4, 2011 | 11:15 AM
coppercutlass's Avatar
Chevy budget Olds powered
those exhaust ports look too square if i remember right my headers run a little taller and little less wider
Old Sep 4, 2011 | 01:01 PM
66ninetyeightls's Avatar
Land Yacht Captain
Odds are thats not a picture of the actual header.
Old Sep 4, 2011 | 01:07 PM
TripDeuces's Avatar
It's definitely an Olds header pattern on the flange. Those openings look more like Edelbrock exhaust ports than stock Olds. A stainless header for $208, what does that tell you?
Old Sep 4, 2011 | 01:13 PM
joepenoso's Avatar
It wasn't made over here?
joepenoso
Old Sep 4, 2011 | 01:24 PM
TripDeuces's Avatar
Here's a set of stainless headers unpolished. They are big money. The Ebay ones look polished which should be even more money. So yes I think they are from overseas. Although that isn't necessarily a bad thing it makes me wonder about that port dimension, fitment, etc. My stainless unpolished headers cost $1k, lets just say I'm skeptical.
Joe it might be worth the $208 to see what you get, you'll have to decide that.
Old Sep 4, 2011 | 02:36 PM
They seem to look like olds headers just the demensions are off but I have had luck with overseas stuff like distributors , aluminum pulleys , etc etc but for polished stainless to be that cheap I see a lot of red flags
Old Sep 6, 2011 | 07:32 AM
joepenoso's Avatar
I guess nobody tried them?
joepenoso
Old Sep 6, 2011 | 08:12 AM
TripDeuces's Avatar
Joe I went back and reread the add. Many red flags here. There is no mention of what years they fit or what body. At the bottom of the description paragraph it states in red Application: Chevy Compatibility
Really?
Like I said, it's your $208. It also states no instructions 'Professional Installations Only'. I'm going to guess no one has tried these or is willing to admit it, that should be your answer.
Old Sep 8, 2011 | 02:23 PM
joepenoso's Avatar
They have a recomendation for 1971 442. They have a better website to see what fits what.....
http://cgi.ebay.com/ebaymotors/OLDSM...item2313effd45
thanks
joepenoso
Old Sep 8, 2011 | 02:25 PM
joepenoso's Avatar
There seems to be 10 different headers to fit the various A body cars including the LT $hevy engine
joepenoso
Old Sep 9, 2011 | 08:03 AM
scubastever's Avatar
this is not my car lol
i saw these headers and am also very curious about them...
i can forego the professional installation instructions, as its not really rocket science to install headers......but i am worried about clearance/fitment.
Old Apr 6, 2012 | 11:13 AM
Oldwolf's Avatar
joepenoso
I Have tried them. The don´t fit a 68 442 Conv, with a big block without serious massaging (torch and hammer).
I think these are small block headers actually and maybee they do just fine on a small block equipped car. The reason for this oppinion are:
-Really good clearence for the starter.(Driver side)
-no place for brake line junction. (driver side)(torch, hammer)
-they hit the backside of the crossmeber (passanger side)(torch, hammer)
-they hit the rear lower bolt of the lower A-Arm (passanger side)(torch, hammer)
-They sit hi up against the floor, which I think is good)
Quality problems:
-unessesary bump at the upside of the passanger side collector.
-the head bolts did not line up (grinding both sides)
-cant use stock oil lines for transmission without bending them around the header (passanger side)
Good:
-beafy flanges
-straigt flanges
-beatiful (even after massaging)
-low price
-can remove oil filter, without other work.
-can remove starter without removing header also.
Not tried them yet, still winter here.
pictures?
Stanley
Old Apr 7, 2012 | 10:53 AM
joepenoso's Avatar
Exclamation
Thanks Wolfy.....you are one of the first to answer back after having bought one.
They're forever on sale on E bay but nobody has first hand experience with them
Old Apr 7, 2012 | 07:17 PM
joepenoso's Avatar
Question
I guess that's why they advertise
so much because nobody is buying then.
joepenoso
Old Apr 8, 2012 | 12:47 AM
Oldwolf's Avatar
joepenoso
I started the car yesterday, no leakage and i´m supriced that they are so quiet.Very little of that hard pinging sound I suspected. I have a 2.5 flowtech X-pipe system, stainless also, and I´m happy so far. If you want pictures of the installation I will be happy to send them.
Stanley
Old Apr 8, 2012 | 06:16 AM
joepenoso's Avatar
Talking
Sure send in some pictures .....\I wonder what they look like after all that banging and heating. I heard they are reproductions of Hooker headers but without the accuracy.
joepenoso
Old Apr 8, 2012 | 06:35 AM
Oldwolf's Avatar
joepenoso
OK, here they are:
Old Apr 8, 2012 | 06:37 AM
Oldwolf's Avatar
joepenoso
and more
Old Apr 8, 2012 | 06:46 AM
Oldwolf's Avatar
joepenoso
And at last. If you want more pictures tell me. This is happening in "real time"
The worst fitment issue is the brake line junktion. Of course It´s possible to change the location of that, but its a lot of work´also.
Stanley
Old Apr 8, 2012 | 02:26 PM
joepenoso's Avatar
Thanks a lot. They are real stainless and brake junction problems with headers are common.
joepenoso
Jolly Green
Suspension & Handling
Mar 1, 2013 10:04 PM
henryk8398
Nov 11, 2009 01:24 AM
BerBer5985
Aug 12, 2009 10:29 AM
my69olz
May 18, 2009 03:40 AM
a64olz
Apr 25, 2009 05:15 PM
