71 442 four-speed?
Old Apr 22, 2007 | 08:15 PM
luckyman15's Avatar
71 442 four-speed?
I just recently bought a 71 442, the guy i bought the car from said it may possibly be a 4 speed car and that there were only a small number of those produced in 71, but unfortunately the car doesnt have the original motor so the number on that engine isnt correct, and for more bad news the car is an automatic right now, but it's a really "mickey mouse" shifter etc. Also there is a hole that looks like it is for a clutch petal next to the brakes, so it got me thinking that maybe some genious tried to make this car a hot rod and screwed it up. This is my first olds so i'm looking for some help from a seasoned veteran. thanks a lot
Tom
Old Apr 22, 2007 | 08:28 PM
2blu442's Avatar
Crawl underneath or look under the carpet to see if there's a shifter hole in the floorboard. If so, does it look factory or not? Should be a slight hump in the transmission tunnel with the shifter hole in it. John
Old May 11, 2007 | 07:59 AM
vette442's Avatar
If your car was a four speed car, the hump would look like this:
Even if it's removed, you'll have a large hole in the trans tunnel - versus a smaller quarter-sized one - for an automatic shfter cable. You'll probably be able to see evidence of seam sealer around the base of where it was too.
Terry
Old Sep 27, 2010 | 04:45 PM
mybmwm3's Avatar
Can someone tell me the correct hurst shifter type for a 1972 442 W30, bench seat car. Thanks
Old Sep 27, 2010 | 07:36 PM
tomsw31's Avatar
The shifter body is a hurst competition plus with an offset. The handle is part number 7305 with two bends in it and an "H" on it. Same on all 70 -72 Cutlass and 442 non console applications.
Old Nov 27, 2010 | 09:21 PM
mybmwm3's Avatar
I can't seem to find the correct 7305 shifter, will any others work for it. Thanks
Ctls442
Jul 26, 2015 11:57 AM
442much
Oct 30, 2010 08:48 PM
ViceGuy
Feb 19, 2007 07:07 AM
ViceGuy
Oct 26, 2006 02:21 PM
