71 442 cam swap
Old Sep 4, 2007 | 07:57 PM
luckyman15's Avatar
71 442 cam swap
i have a 71 442 with a 455 and i want to swap the cam for something more high performance, but i've heard that in doing that i could cause other annoying problems such as a lurching idle and many others. So i was hoping to get some advice from someone who has had good luck with high performance cams. thanks a lot
Tom
Old Sep 5, 2007 | 05:01 PM
luckyman15's Avatar
71 442 cam swap
i have a 71 442 with a 455 and i want to put in a high performance cam and valvetrain, but ive heard that doing that leads to some lurching while idleing as well as other problems. I was hoping that someone who has had success with could point me in the right direction. thanks a lot
Tom
Old Sep 7, 2007 | 07:36 AM
442Harv's Avatar
What size cam did you put in? Most performance cams are not going to idle smooth. You also need to run more intial timing than stock. Also is this a auto trans? If you put in a lot off cam, and while in gear it does this, you may need a higher stall convertor?
Old Sep 8, 2007 | 04:13 PM
luckyman15's Avatar
Well i havent decided what size cam yet, so it still has the stock one in right now. and my timing is a whole different issue, i'm starting to think that the genius i bought the car from thought he had a little more knowledge than he acutally did because there are some pretty "mickey mouse" fixes etc. throughout the car. Also yesterday i bought a Munice 4 speed for it so i'm pretty sure that i'll be putting that in the car. thanks a lot for replying.
tom
Old Sep 8, 2007 | 05:54 PM
$tryker's Avatar
Try something like this: http://store.summitracing.com/partde...2&autoview=sku
This should put you in the performance ball park, and not give you any drive-ability problems. Stick with Crane, their cams are top notch. Stay away from Comp cams, they're better set-up for Chevy. Good Luck!
Old Sep 9, 2007 | 08:22 AM
Oldsguy's Avatar
Past Administrator
I merged you threads for you...
Old Sep 9, 2007 | 08:36 PM
luckyman15's Avatar
thanks a lot everyone who replied, you were a really big help
Tom
grmchne78
Jun 25, 2015 06:23 PM
Oldsmaniac
Jun 20, 2014 05:44 AM
Uncle Hulka
Mar 12, 2014 03:41 PM
jarrod
Apr 1, 2013 09:27 PM
65Delta88
Jan 4, 2011 09:47 PM
