70 442 w30's-Goodyear or Firestone tires?
BFGoodrich (PERFORMA GT ??)
B2MF L9DM
B2 - date = 1st week of 1971
MF - manufacturer & plant = GOODYEAR Los Angeles, CA
L9 - size = G70-14
DM - type = fiberglass belted with "white stripe"
can you ad pics of the complete tire & tread? how about the wheel and the date codes by the valve stem? what's the body build date on the cowl tag and completion date on the door sticker?
B2MF L9DM
L9 - size = G70-14
Spare
B2MF L9DM
L9 - size = G70-14
B2MF L9DM
L9 - size = G70-14
Hurst68olds - Where can I (or did you) find the info to decode the tire date code info?
that is an interesting tire - first I've seen - thanks for sharing!
the first I saw of a Goodyear tire decode was ~2000 from Galen Govier in his "Chrysler Corporation Part & Casting Numbers Book 1962-1974 VOL. II"
since then I've seen Corvette crowd based info in print & more recently this: http://anghelrestorations.com/upload...tires_v1.3.pdf
looks like the "PLANT" may not be accurate in my above decode as Goodyear Los Angeles used "NE" in the above format & changed to "MF" in the following 10-11 digit format ????
here's a current DOT plant codes & location - I believe as some US plants were moved overseas, the equipment & DOT code moved with them http://www.harriger.com/tires.htm
