69 442 spark plugs
Old Jun 13, 2010 | 06:18 AM
derek nesdoly's Avatar
olds..older..oldest
69 442 spark plugs
Spent yesterday putting in new engine mounts and thot WTH , why not change the plugs . My question is this...has anyone else had problems replacing the #7 plug driver side nearest firewall. I ask because I had to remove the steering coupler to do it , and even then it was nearly impossible to fit in a wrench! I know some cars had the same type of problems due to design flaws eg. late 60s Cougar #4 plug...had to remove AC condenser...Land Rover...had to cut out crossmember to change clutch. Thanks for any input or suggestions. Derek
Old Jun 14, 2010 | 11:33 AM
MX442's Avatar
I have no problems with #7. #8 is a PITA on A/C cars. It is easier to reach up from underneath. I use a socket with a hex end. Then you can turn it with a box end wrench.
Old Jun 14, 2010 | 02:13 PM
X 2 # 8 the Bear IMHO
bob p
Apr 10, 2015 01:55 PM
cargo442
Sep 11, 2010 11:11 PM
85ttop442
Apr 27, 2010 07:20 PM
KQQLCAT
May 6, 2008 08:18 PM
The_Jeremiah
Jan 26, 2008 01:56 AM
