68 cutlass/442 decklid question
Old Nov 29, 2021 | 10:40 AM
tiogatwister's Avatar
Can some verify that a 68 4 door cutlass decklid is the same as coupe decklid or is it common to the convertible for the 68 model year?
thank you
Old Nov 29, 2021 | 11:37 AM
shamusj's Avatar
Confirmed - I've sourced one from a 4 door and fit perfectly on convertible.
Old Nov 29, 2021 | 11:42 AM
Ok, so 4 door and convertible are the same and hardtop/coupe are a stand alone..
thank you very much for the quick response.
Old Nov 29, 2021 | 11:55 AM
The easy way to tell is to look at the upper corners. Square corners = coupe. Rounded corners = convertible or more-door. This is why you see more "convertible" trunk lids for sale than there were convertibles made by Olds. Also note that the convertible trunklid is overall narrower than the one on the coupe. Note where the lower corners of the trunklids fall in relation to the tail lights.
Old Nov 29, 2021 | 05:46 PM
Good comparison, thank you Joe.
servexcell
Mar 2, 2017 08:46 PM
Oldsmaniac
Oct 22, 2016 11:22 AM
RROLDSX
Nov 22, 2013 09:44 AM
yeahbuddy
Jun 29, 2010 09:48 AM
DR_DAN
Aug 22, 2006 02:14 PM
