68 442 Rad Support
That's what I'm thinking as well. I just remember seeing somewhere that there might be a difference in a small block car. I just want to make sure before I buy. The one I'm looking at is from a Cutlass.
I'm pretty sure the only other difference than the radiator support is the provisions for the two different styles of hood latch. I'm pretty sure the support is slightly different depending on which latch design you have. (I seem to remember there are 4 different part #'s in the assembly manual for the radiator support)
its funny that this thread poped up because i looked at this the other day and was wondering about the slotted mounting holes to the frame - i have only seen round ones, must be early design ?http://cgi.ebay.com/ebaymotors/1968-...item35b4d7990f
There won't be any part numbers on the piece. The numbers were for reference while they were on the assembly line.
The early "paddle" style hood release has part numbers
398381 (non heavy duty cooling)
400821 (heavy duty cooling)
The later "pull" style hood release has part numbers
402272 (non heavy duty cooling)
402274 (heavy duty cooling)
The difference between the "early" and "later" designs is the location where the hood release assembly mounts
These numbers can be seen on pages 11-109 & 11-110 of the 68 assembly manual.
There may be more differences but I spent a bunch of time trying to figure out what core support I have & those were the only differences that I could find
I've only had a couple of core supports but both had slotted holes. The assembly manual shows them slotted on page 11-140
StickW31
November 3rd, 2013 05:48 PM
1k442
June 5th, 2013 11:53 AM
scubastever
May 5th, 2009 01:20 PM
