68 442 convertable suspension
Old Dec 2, 2014 | 07:04 AM
wisniows's Avatar
Im performing a frame off restoration and during reassembly i am noticing the driver side of the vehicle is approx 1/4 to 1/2 inch lower than the passenger side. During reassembly i have replaced all suspension bushings shocks, and springs i have replaced the springs a second time suspecting one of the springs are collapsed. Can anyone guide me to finding the issue before the restoration was performed the vehicle was sitting level, are there any adjustments that im not aware about etc. Thanks for any inquiries and knowlegde that someone may be able to help me with
Old Dec 2, 2014 | 09:17 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Is the body back on the frame? Make sure the frame is square and level. Sounds like it is but cant hurt to check. Tougher to do with the body on it. Make sure the springs are sitting in their respective pockets properly. Dont tighten any of the suspension bushings until the total weight of the assembled car is sitting on the frame with the body to frame mounts tight. Thats the body, drive train, interior etc...If you did tighten the suspension without the assembled weight of the car on it then loosen the front and rear upper and lower control arm bushings and see if it levels out. Then with the total vehicle weight on the chassis tighten it down again.
The chassis service manual will have the specs on what the corner tolerances are.
wisniows
Nov 29, 2014 07:19 AM
Meinfield
Dec 1, 2012 06:44 PM
dyter19
Aug 9, 2012 07:34 AM
Arctic Olds
Jul 20, 2011 02:11 PM
330oldsmobile
Feb 9, 2011 01:56 PM
