67 convertible rear window replacement
Old Apr 14, 2014 | 08:23 AM
nothingbeatstheclassics's Avatar
Has anyone ever had to do this before? The top is in amazing shape, but the rear window is cracked and separated from the canvas, I am just curious on what kind of costs I might run into to have this done. I am thinking about buying a 67 442 convertible and wondering what to offer the guy
Old Apr 14, 2014 | 08:31 AM
lemoldsnut's Avatar
To correctly replace the back window assembly you should be taking the top off to get it on correctly. The problem also is that there maybe different manufacturers of the top you have and a replacement could not fit if just a little different. The odds are best that you should replace the top. They are a few hundred dollars and it can be done at home with some attention to detail. I did mine and it came out great.
Larry
Old Apr 14, 2014 | 08:36 AM
Dang, was really hoping to not hear that, the top really is in too good of shape just to get rid of. Honestly though I think you are right if I bought a new window, it would cost alot more than a new top just to get it installed professionally, I will have to look into it farther tonight when.uk get home
Old Apr 14, 2014 | 09:02 AM
66luvr's Avatar
Rear curtain replacement cost me $250 last time I had to have one replaced, about 5 years ago on a 66 98 convertible. The entire back of the top must come loose. The curtain is a part which stands alone, manufacturer has no bearing on replacement, style may matter but probably not.
Good luck,
wyteon
Vista Cruiser & Wagons
Nov 30, 2018 11:33 AM
1965cutlassragtop
May 8, 2012 01:00 PM
f-85
Jan 16, 2012 06:10 AM
a6m5zerosen
Nov 28, 2009 03:58 PM
redrumloa
Jul 28, 2008 06:16 PM
