67 442 front window lower channel rust fix?
Old Sep 3, 2019 | 06:22 AM
Maverick4164's Avatar
Maverick4164
Question 67 442 front window lower channel rust fix?
I am re-starting the restoration of my dad's '67 442, that he did not get finished before his passing. Does anyone have a solution for the windshield lower channel rust issue? My brother says it is too far gone to patch it and needs a new lower channel welded in place. I have had trouble finding one. Also, what does the term "two door post" refer correlate to....is that a two door sedan or a coupe? Thx!
Old Sep 3, 2019 | 06:38 AM
edzolz's Avatar
Your only option is to find a donor car with a good piece and weld it in place of the rusted one (a major undertaking). A two door sedan/post is a body style that has a frame around the door window as opposed to a hardtop body that has no window frame. A coupe is the same as a two door post.
Old Sep 3, 2019 | 06:41 AM
Oldsmaniac's Avatar
I believe that lower channel is reproduced, saw some on Ebay....
Old Sep 3, 2019 | 07:17 AM
You can get the windshield channel repair panel. It's the same on Chevelles.
http://dynacorndepot.com/windshield-...chevelle-64-67
Old Sep 3, 2019 | 07:32 AM
Gpc1's Avatar
I had pinholes in my 65 front window, wasn’t bad enough to consider replacing the channel. I used por15 epoxy putty then painted the entire window frame with por15 paint. No leaks no issues and no more rust. The rear window was a different story
i did replace the lower channel. It was a challenge but everything came out good.
Hope it all goes well.
Old Sep 3, 2019 | 09:02 AM
jaunty75's Avatar
"Coupe," in Oldsmobile lingo, just means that it has two doors. A "Holiday Coupe" does not have a post. A "Sports Coupe" or "Club Coupe," which are both terms that have been used by Oldsmobile, means a two-door with a center post. But I don't think these coupes actually had a center post. What they have is a frame around the front and rear side windows whereas the Holiday Coupes do not.
This station wagon has a true center post or pillar.
Old Sep 3, 2019 | 11:11 AM
Run to Rund's Avatar
[QUOTE=jaunty75;1194941]"Coupe," in Oldsmobile lingo, just means that it has two doors. A "Holiday Coupe" does not have a post. A "Sports Coupe" or "Club Coupe," which are both terms that have been used by Oldsmobile, means a two-door with a center post. But I don't think these coupes actually had a center post.
yes they do.
Old Sep 3, 2019 | 11:38 AM
jaunty75's Avatar
Originally Posted by Run to Rund
yes they do.
Cool. Thanks. You don't very often see photos of them with their doors open.
Old Sep 3, 2019 | 04:36 PM
I have a front windshield area, including cowl and firewall, if someone needs more than the patch panel.
Old Sep 3, 2019 | 06:47 PM
2Olds4U's Avatar
Majored in rear tire demo
Maverick, I got this from Tamraz a few years ago for my 67. The fit to the wiper grill is perfect. You do have to tweak it at the A pillar covers a bit. What I did like about it and nobody else had one like it was that it had the rivets for the molding clips built into it.
Old Sep 3, 2019 | 08:36 PM
Maverick4164
Thumbs up
Thanks for all of the great info, everyone. I got a new channel ordered off of eBay, today. Will see how it goes. Thx!
olds71s
Body work
Sep 19, 2016 11:38 AM
edzolz
May 28, 2015 04:22 AM
therobski
Apr 21, 2015 01:24 PM
jankyrre
Body work
Mar 26, 2014 02:09 PM
68Tom
May 11, 2009 11:11 AM
