'67 442 Axle search continues.....
Old Jun 19, 2007 | 04:57 AM
Rockbottom07's Avatar
Post '67 442 Axle search continues.....
My search for the elusive road noise led me to a bad drivers side axle on my 442. I hoping to find someone out there that has, or knows where I can get, a replacement. Here is what I know the differential in the car. It is believed to be original.
* "P" type differential (converging ribs on the case)
* 10-bolt irregular cover (notches on either side @ 9 o'clock and 3 o'clock)
* Posi (ratio ?)
* Axle length - 29 3/4" outside of the flange to the end.
* Non-C clip type
The car was purchased the first week of January, 1967. From what I understand, '67 was a transition year and it appears my car received the earlier, non c clip version.
If anyone can provide other applications that used this type of diff, it would be greatly appreciated. I have found information on this site that indicates this was used on '64-'70 F-85, Tempest/GTO and '67-'71 Firebirds.
Thanks in advance,
Matt
Old Jun 19, 2007 | 07:34 AM
1k442's Avatar
You do not have an original Olds rear in the car. I think you may have a Pontiac. There are web sites for rears. You may have to look around to find one. Good luck, Ken
Old Jul 25, 2007 | 12:32 AM
thegooddocolds's Avatar
The one to look for is a 12 bolt/12 bolt. 12 bolts on the cover and 12 bolts holding the ring gear. I think they're used in Ch*v's
Old Jul 25, 2007 | 04:37 AM
Are you looking for a whole axle, or just a replacement bearing? If you're just looking for parts, here's one source:
http://www.drivetrainspecialists.com...iac/index.html
HonestDave
Feb 4, 2013 06:35 PM
GreekDog
Apr 14, 2011 12:02 PM
BIGJERR
Feb 20, 2011 02:23 PM
rickbmac
May 19, 2010 07:53 PM
BosMobile
Drivetrain/Differentials
Apr 12, 2009 03:39 PM
