455 in a 442???
Old Apr 5, 2009 | 09:40 AM
delta881972's Avatar
455 in a 442???
any 442 nuts here know if olds rolled out any 68s with the 455 in them?
Old Apr 5, 2009 | 10:06 AM
agtw31's Avatar
no
Old Apr 5, 2009 | 10:12 AM
Only the 68 Hurst/Olds. It's very easy to prove that the 455 was not factory installed. The VIN derivative on the block will not match the VIN of the car.
Old Apr 6, 2009 | 09:14 PM
mugzilla's Avatar
is Fast Enough ...
A very rare non number matching car ...
Would there be Hurst / Olds document showing the c orrect #s for the engine ..?
Old Apr 6, 2009 | 09:17 PM
442ChicInOklahoma's Avatar
Me and my dad have a 455 bored over 30,000s in the 71 442 w-30 we are restoring
Old Apr 7, 2009 | 08:57 AM
Um, what numbers are you looking for? It will be a normal 396021 F block. Heads will be either D heads for non-A/C cars or C heads for A/C cars. The intake is a normal 1968 cast iron 398662 casting. Exhaust manifolds are also normal 1968 X/Y castings.
Old Apr 7, 2009 | 09:28 AM
csstrux's Avatar
The 455 was available in the cutlass in '71. I'm not sure, but think 69 was the first year though. Corporate mandate allowed a maximum displacement of 400CID in the A body cars up until either '69 or '70 due to the success of the cars like the Hurst. I'm not sure on all the details, but here are a few basics. Others with better memory/ history may chime in on this to fill the holes.
Old Apr 7, 2009 | 09:38 AM
Eric Anderson's Avatar
69 HO had a 455, the 455 didn't make it into a 442 until 70.
Old Apr 7, 2009 | 10:38 AM
csstrux's Avatar
That's what I thought, but didn't want to commit
Old Apr 7, 2009 | 10:49 AM
The question was about a 1968 442.
Old Apr 7, 2009 | 07:03 PM
mugzilla's Avatar
is Fast Enough ...
A:The VIN derivative on the block will not match the VIN of the car.
B: Um, what numbers are you looking for? It will be a normal 396021 F block. Heads will be either D heads for non-A/C cars or C heads for A/C cars. The intake is a normal 1968 cast iron 398662 casting. Exhaust manifolds are also normal 1968 X/Y castings.
A:Would it be any specific numbers ...
B:Are those the parts that Hurst would use ...
There were Tempests w/ big blocks that were not available in GTOs'...
Old Apr 7, 2009 | 07:24 PM
I gave you the casting numbers and I said they were the ones used on the 1968 H/O. If your question was supposed to be "are there any unique H/O engine identification numbers?", then the answer is no.
Old Apr 7, 2009 | 07:51 PM
mugzilla's Avatar
is Fast Enough ...
That's what I was looking for ...
A pal of mine raced mopars and had a set of stamps for the blocks they would send him ...
Didn't Olds ship bare number pad blocks also ..?
Old Apr 8, 2009 | 05:46 AM
wmachine's Avatar
Trying to remember member
"Ship" meaning what? (Dealer) replacement blocks had bare pads simply because they didn't come in a car!
Old Apr 8, 2009 | 01:32 PM
mugzilla's Avatar
is Fast Enough ...
That's what I'm curious about ...
I'm just glad my engine number matches ....
Old Apr 8, 2009 | 08:15 PM
thank you Mr. Padavano for answering my question relating to the 455 option in the 68 442! (and for trying to keep the replies on topic lol)
y'all really ran away with this one!
Old May 5, 2009 | 11:47 AM
442much's Avatar
Moving off topic here but I think the original question has been answered. My 442 has the T code in the VIN and has the 455. I am the second owner and bought the car when it was 3 years old and had 29000 miles. I've checked the numbers on mine and spoke with the original owner decades ago. I asked about the engine and wondered if he did anything with it. I didn't want to lead him on. I asked if he had any work done to it. He said "No". But he did recall having an issue about three months into ownership. He said there was a problem with the crank and it was covered under warranty
He said he brought the car back to the dealer and they had it for three days. After he picked it up he said it ran like a "scalded cat". He said he was very satisfied with it and the peformance was awesome.
Now to the point. The casting of my 1976 442's 455 engine is 396021F. The is no small letter A after that. That indicates a 1968-72 block. The pad where the serial number is located says 3635.
In 1979 after I got the car I took it to the track just to see how she ran. On street tires (G70R 15 Uniroyal Steel Belted Radial RWL) I ran a best time of 14.33 @ 97 miles per hour in the quarter mile. After some mods years later (true dual exhaust, ported & polished "C" heads, 9.75:1 pistons, Kenne-Bell cam, lifters etc.) the best time improved to 13.96 @ 103 miles per hour. Cars getting old and I haven't taken her to the track in decades.
So, did my car get a used engine? Was it a factory replacement? What do the four numbers mean if anything? Why would a dealership use an engine from an earlier body style. Thoughts?
Old May 5, 2009 | 12:17 PM
wmachine's Avatar
Great discussion material, Ken. Should be a new thread with an appropriate title so it can be found!
But you knew that, right?
Old May 5, 2009 | 04:50 PM
442much's Avatar
I knew that. But I was asking because the topic popped up. I'll start a thread and see what happens.
dp442
Feb 15, 2011 04:22 PM
sx455raidercelticfan
Nov 23, 2010 05:45 AM
SKINNY IL
May 14, 2010 07:12 AM
egknz
Jul 21, 2009 01:09 PM
