442 with a manual tranny
Old August 17th, 2009, 08:07 PM
pureplaya442's Avatar
Does anybody know if the shifter coming out of the boot had "442" imprinted on the shaft. i just heard about this, whether or not it's true is beyond me
pureplaya442 is offline
Old August 17th, 2009, 10:36 PM
Ozzie's Avatar
Thumbs up 442 with a manual tranny
The 1965 442 which I have has "Hurst" just below the ball, and "442" further down (in the curve of the shifter).
Ozzie is offline
Old August 17th, 2009, 11:31 PM
is Fast Enough ...
mugzilla's Avatar
what year are we talking about here ..?
mugzilla is offline
Old August 18th, 2009, 02:11 AM
jensenracing77's Avatar
65, 66, 67. i think that is the only years. i am not sure about 68 but don't think it did.
jensenracing77 is offline
Old August 18th, 2009, 02:50 AM
Nilsson's Avatar
68 has 442 on the shifter.
Nilsson is offline
Old August 18th, 2009, 02:59 AM
Yellowstatue's Avatar
Smile Stick it to me
X4 on the '68 shifter...
Yellowstatue is offline
Old August 18th, 2009, 06:09 AM
66400's Avatar
'69 also displayed H and 442.
Henry
66400 is offline
Old August 18th, 2009, 06:52 AM
Trying to remember member
wmachine's Avatar
Holy cow, guys!
Every year (through '73) except 1964, the stick 442s had "442" on the shifter handle.
wmachine is offline
Old August 18th, 2009, 06:54 AM
wmachine's Avatar
Cool, Ozzie. You must have a 3-speed. What the date on your build? March '65 or later?
wmachine is offline
Old August 18th, 2009, 11:09 AM
I was curious for my 70 442
Old August 18th, 2009, 11:56 AM
68Tom's Avatar
Hey Kurt, I'm definitely not questioning your knowledge, but what is this shifter all about? (I also saw an "original" shifter like this on eBay as well.)
Just has the "H"
http://cgi.ebay.com/ebaymotors/1970-...Q5fAccessories
Here's the original
68Tom is offline
Old August 18th, 2009, 12:00 PM
Originally Posted by wmachine
Holy cow, guys!
i have never seen a 70-72 with 442 on the lever.
Old August 18th, 2009, 12:24 PM
68Tom's Avatar
So, if our tally is correct it looks like this:
1965: "442" and "Hurst" on the arm
1966: ?
1967-69: "442" and "H" on the arm (with the H lower on the arm than the 442)
1970-72: just an "H" on the arm
Is this correct?
Apparently here's a '67 Hurst shifter.
http://cgi.ebay.com/ebaymotors/1967-...Q5fAccessories
68Tom is offline
Old August 18th, 2009, 12:46 PM
wmachine's Avatar
[/URL]
Don't hesitate to call me out, because if I'm wrong it won't be the first or last time I've been wrong!
I was under the impression that the shifters with only the "H" were non-442 applications in '70-'73 as it was in previous years, but I see that just didn't register with me that they dropped the 442 off the handle in 1970.
wmachine is offline
Old August 18th, 2009, 01:24 PM
My442's Avatar
My 70 442 has the correct #7169 handle, and it says "H".
My442 is offline
Old August 18th, 2009, 01:26 PM
wmachine's Avatar
1966: ?
Is this correct?
[/URL]
Now that I've extracted my foot from my mouth (leaving more room), in 1965, the only Hurst Shifters were the 3-speeds (with the HD F*rd toploader) option M14, starting in March '65. Those '65 442 3-speed shifters were the only manual shifters that had the whole word "HURST" on the handle.
In '65, the 4-speeds were still Muncie shifters and had only the "442" on handle.
In '66-'69, all 442s (all 3 and 4 speeds) had "442" and the "H" at the bottom, and all non-442s (all 3 and 4 speeds) had just the "H" at the bottom.
Additionally, '66s were square at the top and not tapered.
wmachine is offline
Old August 18th, 2009, 04:09 PM
68Tom's Avatar
Cool. Good info to know. Thanks Kurt.
68Tom is offline
Old August 19th, 2009, 06:17 AM
Ozzie's Avatar
Hi Kurt,
You're absolutely correct. It's the M14 H.D. 3 speed just a few months later from Lansing.
Ozzie is offline
Old August 19th, 2009, 07:21 AM
wmachine's Avatar
Hi Kurt,
So you also have a column 2 "B" on your firewall tag?
Pics, please! Love to see one installed on the car!!
wmachine is offline
Old August 19th, 2009, 11:41 AM
Just has the "H"
This is an aftermarket Hurst Competition Plus for a 70-72 with console, as demonstrated by the bolt-on handle. All factory shifters had the snap-in handle.
joe_padavano is offline
Old August 25th, 2009, 08:12 AM
dan1s's Avatar
Here is a picture of my 68' 442 shifter.
dan1s is offline
Old August 26th, 2009, 03:08 PM
69droptop's Avatar
442 shifter
My 69 442 has a Hurst shifter, but it has the straight handle instead of the curve. It has Hurst on the shifter, but obviously not the 442 and the H. Would it be possible to find the correct shifter handle and bolt it into my shifter?
I'm pretty sure the transmission is original, so somewhere along the way, the shifter got switched out. Any advice is appreciated. Thanks!
69droptop is offline
Old August 27th, 2009, 08:12 PM
yogi442's Avatar
1966: ?
Is this correct?
My 66 has the stock shifter and has "Hurst" and "442" on it.
yogi442 is offline
Old August 28th, 2009, 06:52 AM
wmachine's Avatar
We need to talk! PM sent.
wmachine is offline
Old August 29th, 2009, 09:04 AM
wmachine's Avatar
Okay, Yogi and I did some more checking and found that his '66 doesn't have the word "HURST" on the handle.
The word "HURST" on the handle should be '65 3-speed only for Olds.
wmachine is offline
Old February 10th, 2010, 04:07 PM
damascus's Avatar
bringing back a 6 month old post, i know... would some of you factory 4-speed guys mind posting a few photos of your 4-speed console? i have a TH400 in my '71 and am saving my pennies for a Tremec 5-speed. i'm curious if i can get the Tremec shifter to work with my current console or if i'll have to change some things... how similar is the automatic center console to the 4-speed center console?
no worries, purists... it's not an all-original #'s matching car!
damascus is offline
Old February 10th, 2010, 07:46 PM
For 1970-72 they are the same. The manual trans consoles use an adapter that bolts on top and mounts the shifter boot. The console has score lines on the underside where it needs to be cut out to turn the AT console into an MT console. The MT adapters are available as repros.
Old February 11th, 2010, 06:48 AM
damascus's Avatar
thanks! found it at thepartsplaceinc.
damascus is offline
Old February 11th, 2010, 08:20 AM
vette442's Avatar
Here's what the 4 speed console looks like together. You'll need to cut or replace your woodgrain insert.
By the way, my car had a Richmond manual trans in it weeks before I bought it in 2002 and it worked with the stock console (not so much with the factory floor hump setup though... ) It's back to an M20 now though.
Terry
vette442 is offline
Old February 11th, 2010, 09:10 AM
My442's Avatar
Holy cow, guys!
Wrong.
70-72 have an "H" only.
My442 is offline
Old February 11th, 2010, 12:31 PM
  #31
Actually, you need to replace it. The AT woodgrain is too short since the AT shifter is further back on the console. Repros are available.
Old February 12th, 2010, 05:12 PM
  #32
TK-65's Avatar
Originally Posted by My442
Wrong.
Eh, that was covered about half way thru the thread.
Where did Ozzie go? I want pics of the 3 speed 65!!!!
TK-65 is offline
Old February 12th, 2010, 05:28 PM
  #33
todd66442's Avatar
Sound like a rare bar man. Hi RamZ!!!
todd66442 is offline
Old February 12th, 2010, 07:18 PM
  #34
damascus's Avatar
more on Tremec 5-speed conversions: i understand that Popular Hot Rodding is doing a magazine piece on a 1965 Olds Cutlass... the PHR Project Car is getting a Tremec manual transmission next. look for the feature sometime this summer.
http://www.popularhotrodding.com/tec...***/index.html
damascus is offline
Old March 14th, 2010, 06:09 PM
  #35
bummerino's Avatar
66 442 shifter
I went to the garage and pulled out my shifter from my pile of parts....mine has the 442 With the "H"....
bummerino is offline
Old March 14th, 2010, 06:10 PM
  #36
bummerino's Avatar
good thing....
I was a mechanic, I would have starved as a photographer!!!
Old March 16th, 2010, 09:32 AM
  #37
Elephant_Engine_Ernie's Avatar
This is an absolutely great thread! Good info and pics!
Elephant_Engine_Ernie is offline
KidCutlass62
September 23rd, 2014 03:20 PM
Bobac455
February 6th, 2014 02:04 PM
L69
January 5th, 2012 01:29 PM
Prophe'c
April 16th, 2010 08:50 AM
RAMBOW
May 21st, 2009 04:56 AM
Quick Reply: 442 with a manual tranny
