442 Gearing
Old Oct 21, 2010 | 06:28 AM
crjeeper's Avatar
442 Gearing
So I just bought a 1970 442. It has the TH400 with the 455 bored to a 468. The owner said it either has 4.56 or 4.88 gears, I haven't had time to figure out which gears it has. It was built to race the 1/8 mile and I want it for a daily driver now. Any suggestions on what gears to run?? I was thinking 3.73. I'm not going to be driving on the highway a lot but I will occasionally take it on the freeway but I still want it to get up and go.
Old Oct 21, 2010 | 09:56 AM
svnt442's Avatar
Well I had a mild 455 in a 70 Cutlass with 2.56 gears and still ran a 13.89 @ 90 with it so it all depends on what you want out of the car. It would have come stock with 3.23 gears. That's what I have in my car now and they work just fine. I haven't taken this car to the track but it pulls nicely for sure.
Old Nov 1, 2010 | 09:25 PM
crjeeper's Avatar
Good to know, Thanks. I'm leaning towards 3.55 gears and plan on doing a 20-40 miles on the freeway occasionally. Do you know your shift points with the 3.23 gears? I may be better off going back to 3.23's
Old Nov 1, 2010 | 09:38 PM
svnt442's Avatar
I don't trust my tach so I don't know what the shift points actually are.
Old Nov 2, 2010 | 03:45 AM
sicky olds's Avatar
NôôB
i run 4.10s on my caprice and do daily driving with it. as far as the H/O goes it is what ever the stock was for it, dont know if that helps but there ya go lol
Old Nov 2, 2010 | 04:28 AM
My442's Avatar
3.23 if you do highway driving, 3.91 if you don't.
Old Nov 2, 2010 | 04:57 AM
Rickman48's Avatar
My nephew put 3:55's in his '69 with a 494 stroker, and says it's too low for the highway - 3000 RPM @ 65 miles per hour.
But one heck of a street gear! Especially with gobs of torque! It's a Strange 12 bolt.
He's yet to make a pass, but I'm thinking close to 6 grand through the traps @ about 120 MPH!
Low 11's??
Old Nov 2, 2010 | 06:32 AM
citcapp's Avatar
I run 3:08's behind my 455 in my 57 (heavy car) and it has no problem when I hit the go pedal. bored 30 over 10.5.1 compression with Edelbrock heads full roller set up Cat rods 2800 stall converter. It will fry the tire off the car if I get on it to hard. 2500 rpm 65 MPH
Old Nov 16, 2010 | 06:15 PM
442b's Avatar
I had this debate a few months ago in a thread I posted trying to figure out what the gears are in my 72 442. A lot of talk about it but every seemed to lean towards 3.23's........ I'm still not convinced because I tach 3000rpms @ 65mph. They seem higher to me. I tried counting turns of drive shaft, even changed the rear end oil & checked the Ring Gear. Also, checked the lettering on the tube, still unsure. I had 3.23's in another 72 Cutlass Supreme I owned, but that car was an automatic and didn't have a tach but seemed to run nice on the highway.... Speed limit was 55 back then though. Good luck on comfortable gearing. I'd go with the 3.23's for highway.
Bluemeanie
Drivetrain/Differentials
Sep 23, 2012 05:37 PM
Zemanek889
Jul 14, 2012 05:02 PM
1970_442
Jul 6, 2010 11:07 AM
procharged70cutlass
Dec 21, 2009 03:24 AM
jonstringer
May 24, 2008 12:45 AM
