442 4 spoke Steering Wheel
Old Apr 23, 2007 | 07:03 PM
CheckM8t's Avatar
Does anyone know how to remove the center cap from a 442 4 spoke steering wheel?
Old Apr 23, 2007 | 08:52 PM
2blu442's Avatar
Gently pry off the horn button, you may be able to do this with your fingers. Under that you'll see three phillips screws to remove the horn ring, and under that six screws to remove the sport wheel. After that's off remove the large nut on the steering shaft and use a wheel puller to remove the hub. Oh yeah, you might want to remove the positive battery cable first, to keep the neighbors happy John
Old Apr 23, 2007 | 11:36 PM
That's it. I would only add that as you remove the horn contact ring, be careful to catch the small eyelet, spring, and plastic retainer in the top of the plastic post that sticks up through the steering wheel hub. The retainer has a small nib that locks in place with a quarter turn but it often works free so that once the horn ring is removed, the spring launches itself across the garage.
Old Apr 24, 2007 | 06:24 PM
CheckM8t's Avatar
Thanks...
I will give it a try this weekend.
Troys Toy 70
Aug 20, 2015 09:58 AM
kbdecatur
May 10, 2013 08:04 PM
cheven
Apr 5, 2012 10:05 AM
