1987 442 rear end
Old Aug 20, 2013 | 12:56 PM
Fastbrianman's Avatar
1987 442 rear end
I found a wrecked 87 442 in the junk yard today.
Any chance that it is an 8.5 rear end?
Thanks,
Brian
Old Aug 20, 2013 | 01:09 PM
88hurstolds's Avatar
www.gbodyolds.com
Yes, crawl under and look and see if it has square fangs on the bottom.
Old Aug 20, 2013 | 02:16 PM
Thanks,
Brian
If it's a real 442 with the original rear, it will be an 8.5" 3.73:1 axle.
Old Aug 20, 2013 | 06:54 PM
Thanks, Going back to get it in the morning. It is the real thing but it was trashed. Wrecked up front, engine and trans gone some one destroyed the console and dash pulling the stereo system out of it. The damn yard lifted it with a loader under the roof and busted the glass and warped the quarters and dented the drivers door. The only good stuff left was the door panels the steering box and the rear end.
Thanks,
Brian
Old Aug 20, 2013 | 06:58 PM
Octania's Avatar
might be a posi too
maybe get the driveshaft if it's ok, to match
special code OD trans? Look for a Z among the ID plate letters
Old Aug 20, 2013 | 07:00 PM
66400's Avatar
Grab the speedo cluster.
Old Aug 20, 2013 | 07:52 PM
brownbomber77's Avatar
What...about...THE LIGHTNING RODS?!?!?!?!? haha Were they in that model or just the H/O G-bodies?
Old Aug 20, 2013 | 07:55 PM
oldsmobiledave's Avatar
Fyi
Also grab the dash inserts & matching pieces from the console. This is the only year that they are not crappy looking wood & fit all the 81-88 models. I have resold complete sets for over $200 .
If the trunk lid is still on the car the sticker on the underside will include the option codes for the 8.5" ring gear (G87), the 3.73 gears (GT4) & posi if applicable (G80).This will verify that the car is in fact a 442 since no other Olds A body got the 8.5" rear end that year.
Fail!
FAIL!
Only in the 83-84 HO from the factory.
Old Aug 20, 2013 | 07:56 PM
ThePackRat's Avatar
Big Daddy No Bucks
Most definitely if it's still there ...
1 year only 120 speedo.
Nope ... 83/4 Hurst only.
Old Aug 21, 2013 | 03:24 PM
BlackGold's Avatar
Are you serious?! I cna't stand the crappy black plastic inserts in my '87 442 compared to the nice burlwood ones that were in my '85 442. They may not have been real wood, but they looked a hell of a lot better. To each his own, I guess.
Everything about the '87 is cheap compared to the '85. The only good thing better in the '87 is the 120 mph speedometer.
350TurBRO
Sep 12, 2014 11:52 AM
monzaz
Mar 20, 2009 02:28 PM
monzaz
Feb 15, 2009 07:33 PM
easytobedead
Drivetrain/Differentials
Aug 30, 2008 06:04 PM
