1969 442 stripes
Old Apr 25, 2009 | 03:45 PM
derek nesdoly's Avatar
olds..older..oldest
1969 442 stripes
My assembly manual states that stripes were "standard on 442's". Would the wise among you please enlighten this neophyte: does that mean ALL 442's were striped and you'de have to delete it on ordering if you wanted no stripe? The optional colours for my Crimson [code 52] post coupe were: black,white or red,and the manual "recommends that paint stripes match top colour or interior trim colour whenever possible" As I have a red car[repainted in 2006] with red interior , if I want to stripe it,am I to have red stripes on a red car? Have any of you seen this combo? Given my druthers, I would like to do white. If so, should I paint [with stencil], or use decals?Thanks, Derek
Old Apr 25, 2009 | 05:21 PM
IDAS 69's Avatar
I'd like to know also.
Also have 69 442, Crimson color but has been repainted. Wondering If mine used to have the stripe. ?????????????
Old Apr 25, 2009 | 10:28 PM
rcorrigan5's Avatar
Randy C.
I'm pretty sure stripes didn't come standard with a 1969 4-4-2 (not 100% sure but real close to it!). The 4-4-2 came standard with 4-4-2 emblems on the nose, fenders and trunk but striping was optional. There were two options for stripes on '69 4-4-2s. Those options were either the W42 (special hood painting) or Y73 (hood paint stripe). The W42 option had a wide painted area for the length of each of the two raised areas on the hood, with a pin stripe surround of each raised area (see manual section 1-4, page 400 of your assembly manual). The Y73 option had a double pin stripe around the two raised areas of the hood (see manual section 1-4, page 401 of your assembly manual). Both of those options also carried a rear deck paint stripe (see manual section 1-4, page 402 of your assembly manual).
The color options for striping are choices. A person wasn't necessarily limited to having the color of their trim for the special painting or stripes options. That was just their recommendation; a person was free to chose the color they wanted. I'm with you on your choice - white would contrast nicely with crimson as well as go with it. Black would go with crimson, too, but I don't think it would show up as well as white. Also, I like the W42 option much more than the Y73 option. My '69 (a work in progress) came with the Y73 option and you could barely see those double pin stripes on the hood, even just a few feet away. When I had it painted, I switched it to the W42 option and now that "special hood painting" is very noticeable!
I've attached a couple of pictures. The cameo white convertible is my current project. The burgundy mist '69 hardtop (also with the W42 option) was my very first car that I bought in April 1972 for the grand total of $1,810, including tax!
Hope this helps.
Old Apr 26, 2009 | 04:59 AM
Here's some 69 442 stripe infromation. Please don't put a Cheby Chevelle stripe on the truck deck.
IMHO opinion it looks like poo poo on a white Rabbit.
http://www.69olds.com/stripe.html
Old Apr 26, 2009 | 06:50 AM
olds..older..oldest
I pledge allegiance...
Thanks Jamesbo,that's an awesome site!Just spent an hour on it soaking up 1969 442 stats and pics. As a recently enrolled ClassicOlds member, I hereby pledge allegiance to all that is Olds,and spit on white- rabbit-poo poo-Chebys...especially Chevelles
Old Apr 26, 2009 | 07:07 AM
olds..older..oldest
Thanks Randy, Problem on my end,as the assembly manual I have is laid out differently[eg. my pages 400-401 show wiring harnesses]My pg.43[?your pg.185] is called paint &trim spec.s, and thats what I referred to in last post. Any rate, I'm sure you're correct,and Jamesbo has pointed me in the right direction as well. Derek
Old Apr 26, 2009 | 08:43 AM
IDAS 69's Avatar
Think I'll leave mine as is....No stripe. Thanks for all the info.
Old Apr 26, 2009 | 01:37 PM
4fortwo's Avatar
Matching the trim color was only an option for the buyer. It would not make the car illegit if you striped it black or white.
Of course, I would go white even with my black interior.
Old Oct 22, 2017 | 09:28 AM
Franswa's Avatar
Manual
where do I get this manual your referring to please!!!!
Old Oct 22, 2017 | 10:22 AM
Go to Google.
Type 1969 cutlass assembly manual into the search box
Press RETURN
Pick a vendor and order one.
Old Aug 10, 2025 | 07:18 PM
jdmoyer's Avatar
It would depend on what the sales code was for your car on the window sticker or dealership documentation. For example, mine is "EE" where "E" is blue so it just means blue on blue, so it wouldn't have the stripes even when the Y73 option was standard for all base 442s except W30 and W31 package. Both Y73 and W42 options used painted stripes. But that's if you wanted to be faithful to the original state of the car, you are the artist.
File Type: pdf
Old Aug 11, 2025 | 05:56 AM
Welcome. This thread is from 2009 and is almost old enough to legally drink. I hope the OP got the answer already.
Old Aug 11, 2025 | 10:20 AM
jdmoyer's Avatar
Hi Joe,
I stumbled upon this thread myself trying to find the the answer for this as I'm in the middle of a restoration project and didn't find too many forms that talk about the stripe options. I just wanted to share somewhere what I have found through my own research in case someone else is looking for it. I've found a lot of good information on this site and wanted to keep it going. Thanks!
501Paratrooper
Paint
Aug 29, 2013 08:52 AM
88hurstolds
Oct 7, 2008 01:50 PM
TopEndMach
Sep 21, 2007 02:20 PM
TopEndMach
Sep 21, 2007 12:49 PM
