1969 442 Production in Switzerland
Old Sep 2, 2017 | 04:53 PM
356Speedster's Avatar
Hello, I am new here in the group. I am in need of some help concerning production numbers. I am very interested in a 1969 442 that is currently for sale here in Switzerland. The car was assembled at the GM factory in Bienne, Switzerland in 1969. I would like to know if anyone could help me find the total number of 442s assembled here in Switzerland in 1969 (I can't imagine it would be many, as the exchange rate at the time would have made them very expensive to the locals).
I did a search here on the forum for old posts similar in nature and the links that might have been useful to me are no longer working (404 Not Found). Any help would be much appreciated.
Thanks, Rich
Old Sep 2, 2017 | 06:09 PM
truckman5000's Avatar
W30
wow i wonder also, none???
Old Sep 2, 2017 | 06:57 PM
oldsmobiledave's Avatar
USA/Canada 442s only
Other than at the Oshawa Ontario Canada plant 442s were only made in the USA. This has long been my understanding.
Anyone know different?
Old Sep 2, 2017 | 08:08 PM
rcorrigan5's Avatar
Randy C.
Rich,
If you can get a picture of the cowl tag and let us know the VIN, people on this site can give you some information on the car in question.
Randy C.
Old Sep 2, 2017 | 10:17 PM
hurst68olds's Avatar
I've seen numbers for 1961 "Complete Knock Down" (CKD) OLDSMOBILE vehicles built at the NJ? plant for (final and/or re-)assembly overseas - I also would be interested in learning more about this process, car & others
Bloomfield NJ is 15 miles from Linden NJ, possible offsite location for final crating??
Old Sep 3, 2017 | 06:12 AM
anthonyP's Avatar
This information is about '67-'69 Camaro's built overseas, as well as the CKD shipped cars, but it may give helpful hints to finding additional information about Oldsmobile's built at those plants, including the Bienne, Switzerland plant.
http://www.camaros.org/foreign.shtml
Old Sep 3, 2017 | 07:47 AM
GM-Montagewerk Biel GM factory in Switzerland
Hi guys, thank you for the help. The GM factory in Switzerland operated from 1935 to 1975. It was called GM-Montagewerk Biel (Bienne). Import taxes on cars were so expensive in Switzerland that GM would import the cars in parts and assemble them locally. The particular 442 I am considering buying is one of those cars. I am an American and love muscle cars, and over the years I've seen quite a few "Swiss made" muscle cars here in Switzerland. I was hoping someone might have access to a list of the cars made in the Biel Bienne factory. Here is the cowl tag, as requested. Where would the build sheet be located on a 69 442? Thanks again for your help. Rich
Old Sep 3, 2017 | 08:23 AM
rcorrigan5's Avatar
Randy C.
There will be others that can provide more detail but, from what I see, it appears from the chassis number (344879131706) that this car was built in Canada for export. Here's what that number means:
3 = GM division = Oldsmobile
44 = model series = 4-4-2
87 = body type = holiday coupe (i.e., 2-door hardtop without a post)
9 = model year = 1969
1 = assembly plant = Oshawa, Canada
31706 = assembly plant sequential number
The rest of what is on that plate will have to be deciphered by others in the know!
Randy C.
Old Sep 3, 2017 | 08:33 AM
Randy C.
Hi Randy, yes, I ran those numbers too, but wouldn't that be 11 for the plant? Thanks, Rich
Old Sep 3, 2017 | 09:57 AM
No, the 1969 code for Oshawa is "1". The sequential build number for that car is 131706. The sequential built numbers were six digits in 1969, not five, but started with 100001, so this is the 31,706th car made at Oshawa that year.
Old Sep 3, 2017 | 10:14 AM
thank you
Excellent. Thank you for the clarification. Then could it be the car was a Canadian SUP, not assembled at, but homologated at the GM factory in Bienne?
Old Sep 3, 2017 | 10:27 AM
The VIN says the car was built in Canada. I don't know what level of "knocked down" was required to skirt the European import taxes, but obviously shipping a less than complete car from Canada to Europe would have been a logistical nightmare if the car didn't run and drive. This is like the 68-69 Hurst/Olds cars - the official story was that Hurst installed the 455 to get around the GM limits on displacement, but common sense tells you that the cars needed to have the engine and trans installed when they rolled off the assembly line. We've since learned that Olds did, in fact, install the 455s on the assembly line. I suspect the same thing with these "knocked down" cars. Likely there were some minor pieces left off so the cars could be "assembled" at Bienne. I've seen 1950s Oldsmobiles with the Bienne tag like this, but not a 1960s car previously.
Old Sep 3, 2017 | 12:11 PM
VC455's Avatar
Barely Registered
GM Canada kept good records and didn't lose them. You may be able to get additional information about your car from them.
Old Sep 3, 2017 | 12:13 PM
good call!! Wonder what info GM of CANADA has on 3448791131706 ?
Old Sep 3, 2017 | 12:40 PM
new image
again, thank you all for your help. the seller was kind enough to provide me with the following image (see below). if anyone is interested in having a look at the car and sharing their thoughts i can post a link to the seller's page. i'd be interested in your feedback. if posting the link is against forum rules i would totally understand and can always pm. i was told by the seller the car is original, two owner (including the current owner) and has only received a new vinyl top and steering wheel. I would prefer the original wheel. thanks again, rich
Old Sep 3, 2017 | 01:19 PM
what is the color combination of the car?
B10 = "Black" vinyl top & "EBONY BLACK" paint
I'd bet *** 2A (02A) = February week 1 build
posting the link is allowed
Old Sep 3, 2017 | 01:28 PM
the body tag appears to be a "blank" LANSING tag, but stamped in the same/similar manner as a Oshawa, ONT tag for 1969
Old Sep 3, 2017 | 01:35 PM
colors and photos
the car is meadow green and a black vinyl top with off white interior. here is a link, you have to scroll down: https://www.usa-autos.ch/autos-cars/neu-eingetroffen/
i would have preferred ebony black. :-)
Old Sep 3, 2017 | 01:37 PM
thanks!! interesting read
notice the '61 numbers above are multiples of 24 as mentioned in the Camaro article: F85s 432/24 = 18 & S88s 96/24 = 4
Old Sep 3, 2017 | 01:52 PM
I wasn't familiar with the Oshawa paint coding
937 592B10
937 = "parchment" bucket seats
59 = "meadow green metallic"
2 = ?
B = "black" vinyl top
10 = "ebony black" stripes
934 652E50
934 = "gold" bucket seats
65 = "topaz metallic"
2 = ?
E = "parchment" vinyl top
50 = "cameo white" stripes
anyone know what the "2" represents?
Old Sep 3, 2017 | 03:03 PM
deciphering
hurst68olds thank you for deciphering that for me. did you see the photos of the car in the link? it would seem then that the car is in its original configuration as the owner says. i will have to see it in the flesh to get a better idea. i am not crazy about the meadow green but maybe i could grow to love it...
Old Sep 3, 2017 | 03:17 PM
tilt
power antennae (what radio?)
power (disc?) brakes
remote mirror
yes, I looked at the pics - it does have plenty of options!
I've always enjoyed the original look & colors that represent the era of the car
Old Sep 3, 2017 | 03:25 PM
documentation
Since the car was built at Oshawa you can get documentation for the car.
You need to contact George Zapora with Vintage Vehicle Services.
1-888-467-6853 George-gm@vintagevehicleservices.com
Old Oct 21, 2017 | 04:14 AM
Holiday69's Avatar
For the Swiss-Cowl Tag ( called as "Plakette" in German ):
2. left Line:
34487-A
3=GM Division, Oldsmobile
44=Series, 442
87=Body Style, 2 Dr. Holiday Hardtop
A=Automatic
3. left Line:
391131709QR
9=Model Year, 1969
1=Assembly Plant, Oshawa Ontario Canada
131706 VIN Sequence Number
QR=Engine Code, 400-Cui. V-8 with Automatoc Transmission THM-400 without C60&W30
4. left Line:
3448791131706
44=Series, 442
9=Model Year, 1969
131706=VIN Sequence number
1. right Line:
0337-10= Swiss Typical Sheet, called as "Typenschein". It's a smaller Sheet at AMA-Spec.
2. right Line:
Release-number, this is a non-Swiss CKD car, also no Number here.
3. right Line:
Color Number this is a non-Swiss CKD car, also no Number here.
4. right Line:
TRIM or Interior Code, this is a non-Swiss CKD car, also no Number here.
The "Body by Fisher" TAG:
The Code 592B10
59=Lower Paint, meadow green
2B=Second paint ( upper ) is a Vinyl Cover in Black Color ( B= for Vinyl Roof Cover and Convertible Top )
10= Paint Stripe on the Hood, Ebony Black
The Code V78= Cars produced for sale in Canada/USA must have a label saying vehicle complies to all Federal/Canadian Motor Vehicle safety standards in effect at time of manufacture. This label is to be left off the vehicle.
The Code 7278E= unknown code. Dealer Located code? I don't now.
Grtz Tom
Old Oct 21, 2017 | 05:38 AM
35tac's Avatar
Welcome to the forum. That is one nice 69. Good luck on the purchase and please keep the forum informed.
Wayne
Old Oct 21, 2017 | 07:15 AM
Holiday69's Avatar
@ 35tac
Thanks for the welcome.
Have the "imaginative" afterwards fetched.
Grtz Tom
Old Oct 24, 2017 | 03:02 AM
Hi Tom, Beautiful car. Hope to see it around CH. Best, Rich
Old Oct 24, 2017 | 08:32 AM
Holiday69's Avatar
Hello Rich,
see this Link to an Swizzerland-Oldsmobile-Forum.
My Name in this Board is Tom76 :-)
Grtz Tom
firefrost gold
Mar 15, 2023 10:17 PM
oldsmobiledave
Jan 23, 2017 09:46 AM
98regency
May 21, 2013 12:27 PM
Benny K
May 5, 2010 04:05 AM
real442
Jan 25, 2008 06:21 AM
