1969 442 - Correct Door Window Guide Roller
Old June 17th, 2017, 07:48 PM
steedaq's Avatar
All,
I had a swivel tip window roller shear off at the threads in my drivers door and am having a tough time finding one that matches the one I removed. I ordered one from OPGI (P/N: CC28078) but the overall length was too short. The window going down would interfere with the door handle linkage. The dimensions that I'm measuring from the one that broke are listed as follows: Roller OD = 15/16", Length from end of roller to glass is approx = 1.3", Overall length prior to breaking appeared to be approx =1.75".
Am I correct to assume that the dimensions of this roller were correct for my car? Does anyone have a part number for one to replace it? as I haven't been able to find it,
steedaq is offline
Old June 24th, 2017, 11:07 AM
steedaq's Avatar
Ok folks. This is what I found out. I believe GM part number 9813200 is the correct guide roller for the lower door track if you can find one. I ended up purchasing Dorman P/N 74407 (currently produced and available) which is just a touch longer (0.200") so I had to move the track just a bit. The Dorman roller is also threaded for 1/4-28, whereas the round nut is tapped for 1/4-20. With improvisation - it will work well.
steedaq is offline
RROLDSX
April 6th, 2016 09:49 AM
johnjuniper
Body work
February 14th, 2015 06:09 PM
RROLDSX
July 24th, 2014 10:41 AM
Doug69Cutlass
May 7th, 2009 08:11 PM
Redog
August 14th, 2008 06:56 PM
Quick Reply: 1969 442 - Correct Door Window Guide Roller
