1968 442 fan shroud Where to buy?
Old September 3rd, 2010 | 06:28 PM
phukinartie's Avatar
Where can you buy a repop fan shroud for my 68 442 I looked around with no luck I seen a used one online for 250 bucks
Old September 3rd, 2010 | 06:56 PM
Run to Rund's Avatar
from the current fusick catalog, download at www.fusick.com
RADIATOR SHROUD AND RADIATOR INSULATORS:
1966-67 Fan Shroud is a fiberglass reproduction
from an outside source we consider a fair reproduction. The 1966-67 shroud was an option and was not installed on
all cars. Shroud brackets are necessary to mount the shroud on cars that were not factory equipped. Brackets are
not available. The 1968-70 Shroud is GM original, with limited supply. The 1971-72 shroud is our new reproduction
and can be used on 1968-70 models, only difference is a larger fan opening. Rubber Insulators are used
between the radiator support and radiator for 1966-72 All Models.
391030
Radiator Shroud 1966-67 Some models 119.00
402995
Radiator Shroud 1968-70 all 115.00
407867 Radiator Shroud 1971-72 all 109.00"
Old September 4th, 2010 | 08:10 AM
COOL!!! Thanks!!
Old September 4th, 2010 | 11:48 AM
rcorrigan5's Avatar
Randy C.
Keep in mind that the fan shroud for the '68 is slightly different than the one for '69-'72. The '69-'72 fan shroud is being used as a replacement for the '68 fan shroud (it fits and works fine). The difference comes in how the upper radiator hose is attached to the fan shrould. In '68, the upper hose bracket attached directly to the upper radiator support plate. For '69-'72, the hose bracket attaches to the shroud.
Randy C.
Old March 2nd, 2014 | 04:15 PM
e129745's Avatar
After Market Shroud Fit/Quality?
Is the PartsPlace.com fan shroud CS1641T any good as to fit function? Anyone get one and discover quality/strength issues?
Price is considerably less than typical and considering getting something from someone unless I'm able to find functional original.
Thanks for any info/ideas,
Patrick
Old March 2nd, 2014 | 04:53 PM
dnmfranco's Avatar
reason they are more expensive a year in itself, and as mentioned not being re-popped.
Have a few if you want to go the purist route but re-pop version will fit as well
Old March 2nd, 2014 | 05:50 PM
Octania's Avatar
yes, the fairly common '295 shroud will work on your '68
but they will scoff at the car shows, as they are inclined to do.
The '68 shroud lacks the exterior or aft side stiffening ribs, easy to spot.
Mr. Franco, I have a '68 that may need a shroud. Still trying to make SURE whether the W30 was supposed to come with one.
Old March 2nd, 2014 | 05:55 PM
wmachine's Avatar
Trying to remember member
The assembly manual says specifically no. And I have found no reason to believe otherwise.
Old March 2nd, 2014 | 06:08 PM
dnmfranco's Avatar
Mr Franco lol they didn't come w one
Old March 2nd, 2014 | 06:49 PM
allyolds68's Avatar
Chris' W30 is an auto. It's suppose to get a shroud according to the assembly manual.
(Section 11, page 113, note G)
Old March 2nd, 2014 | 07:54 PM
wmachine's Avatar
Yikes, quite correct, I was thinking it was a 4-spd.
Old March 2nd, 2014 | 08:42 PM
Octania's Avatar
Dang, citing chapter and verse too.
You guys are GOOD
So, that shroud IS needed on the AT one anyhow.
Ye know my car better than I do it appears
So, what's the build date on my two W30's?
Old March 3rd, 2014 | 03:16 AM
allyolds68's Avatar
You guys are GOOD
Apparently I don't know your car(s) that well because I only thought you had the 68 convertible W30. I didn't know you had two W30's
shamusj
January 13th, 2015 06:44 AM
Bens71442
April 6th, 2014 10:41 AM
rmoths
December 21st, 2013 12:03 PM
KZ442
November 9th, 2010 06:01 AM
