1966 442 cowl tag decode help
Any info on this cowl tag would be greatly appreciated! Thanks.
Warren..
Left side of cowl tag
078 b
St 66-33817
Tr 980 -b
E 2kxg
5vy
Right side
LAN 30153. Body
L-w paint
Let me know if the format makes sense. Thanks!
Warren..
078 b
St 66-33817
Tr 980 -b
E 2kxg
5vy
Right side
LAN 30153. Body
L-w paint
1966 Fisher body cowl tag:
07B is date code, 7= July, B= 2nd week (one digit to many here).
STyle code 66=1966
3=olds division
38=Cutlass V8
17- Body type, 17 is Holiday Coupe
LAN=Lansing Mich assembly Plant
30153= Number assigned to this unit by scheduling dept.
TRim code 980=all black vinyl
B= strato bucket seats
Paint L= Lower body color, L was Tropic Turquoise
W=Upper body color, W was Silver Mist
Columns 1 thru 5 were option codes that required body modification.
Column 1 was not designated with a 1, just the letter(s).
E=option A01, all tinted windows & w/s
Column 2
K=C60 Air Cond firewall piercing
X=hole in floor for auto trans shifter M32 or M33
G=brackets welded to floor for console D55
No option codes for columns 3 or 4
Column 5
V=Body & front fenders pierced for 442 option L69/L78
Y= Deluxe front & rear seat belts A-39
NOTE. If this was a two tone paint car from the factory, Column 1 should have an "O" along with the "E". O would designate piercing for the paint break molding.
STyle code 66=1966
3=olds division
38=Cutlass V8
Column 2
Column 5
