1965 442 Exhaust question
Old Nov 3, 2021 | 08:06 AM
OldsTechGuy's Avatar
My 65 442 is 4 speed and all original, has standard exhaust manifolds. pipes out back appear to be 2". not sure what collectors are but have been told 2 1/2 or 3" out is the way to go . any thoughts on that appeciated !
Old Nov 3, 2021 | 11:37 AM
acavagnaro's Avatar
Not sure how modified your engine may be - since you have the factory manifolds on it I'll assume not too wild. I would avoid 3" without question. I suspect you might actually see your street performance reduced with this size. Way too big for anything other than pretty modified engines moving a LOT of air. 2.5" is fairly common and will work fine but you'd probably be just as good with 2", depending on your modifications.
A well tuned exhaust system should help scavenge the cylinder charge. Going too big on your exhaust size reduces the system's ability to efficiently move the gases out of the system.
Old Nov 4, 2021 | 04:22 AM
Tri-Carb's Avatar
I think Eric is still the only source for an exact reproduction system. They are generally reproducing these several months behind the date of payment:
Muscle Car Exhaust Systems - Gardner Muscle Car Exhaust Systems (gardnerexhaust.com)
Old Nov 4, 2021 | 06:32 AM
jmos4's Avatar
Hi,
The factory system/Gardner is 2 or 2-1/4" and the tail pipes neck up to 2-1/2" only in the chamber section, Walt V use to make tailpipes stock or custom ones that were 2-1/2" the whole way, not sure if anyone else makes them as heard he retired.
My 65 Cutlass running a 455(450hp) is going to be 2-1/2" with a set of Walt's larger tailpipes.
3" might have some issues getting around everything over the axle and wouldn't have the same look as factory pipes unless someone is making a larger version of the chamber style.
Here's a picture of the larger tailpipes on my car:
doesn't look any different from the outside but no neck down above axle like the factory or Gardner system
Regards,,
Jim
Old Nov 4, 2021 | 07:24 AM
Tri-Carb's Avatar
As of the beginning of 2021 I could not find anyone that had resumed production with Walt’s tooling and work. The Parts Place began offering a much cheaper system but it does not have the factory chambered pipes. I could not find chambered pipes offered except as a part of Eric’s complete system.
Old Nov 5, 2021 | 01:55 PM
thank you. when we got under car we saw Flow masters in place so we left that alone. ran new 2 1/2 from there to behind the rear wheels. feels/sounds much better now. thank you
Old Nov 5, 2021 | 01:56 PM
good thoughts. we went 2 and 1/2. good blend of rumble and improved air flow. thank you
brandon reynolds
May 12, 2020 04:39 PM
Bfg
Dec 21, 2018 08:22 PM
Gerald Nickels
Aug 22, 2017 08:47 PM
real57vetteguy
Dec 7, 2011 03:32 PM
toymaker199
Jun 9, 2010 03:29 PM
