14.58 MPG in my 71 W30 with 3.08 gears
Old Jul 16, 2010 | 08:48 PM
MN71W30's Avatar
I checked the mileage on my 442 and was pleasantly surprised. I drove 100 miles down an interstate at 70+miles per hour. I took the back roads home and even wound it up to 124 miles per hour according to my GPS on a long country straight road. I drove it through car craft traffic jams in St. Paul and still got 14.58 MPG. I bet if I took it easy and stayed on the highway I could get 16 mpg with my Olds.
Old Jul 17, 2010 | 05:10 AM
Lady72nRob71's Avatar
That is pretty good with the 455 - I would be proud! My 350 got an avg of 19.5 over a 1900 mile trip from Geogia to TX, including going through the Smokey mountains.
19 is what the mid-sized v6 suvs and minivans got when i took 2000-3000 mile vacations, so i do not feel bad.
Old Jul 17, 2010 | 01:52 PM
The best that I ever got with my '70 SX back in the mid 70's was 13.6 on the highway, and I am assuming that it had the factory 2:56's, but I don't know for sure. I put the speedo needle past the right hand turn signal indicator once, so I don't think that it had too stiff of a rear gear in it. My '71 350 with 3:42's gets 12 mpg highway.
Old Jul 17, 2010 | 04:10 PM
jensenracing77's Avatar
my Rallye 350 is at 16 MPG with 3:42. everyone needs to remember to check if there odometer is accurate. many people think they are getting one thing but if the odometer is off then it will be something differant. i check mine with a 50 mile stretch of highway and using the mile markers. a GPS will work good also.
Old Jul 17, 2010 | 06:52 PM
MN71W30's Avatar
I hear ya on the accuracy. Mine is right on the money.
Old Jul 17, 2010 | 06:54 PM
MN71W30's Avatar
Did you have a 4 bbl on the SX? It seems that the Qjet 4 bbl carbs might be a little better on gas than a 2 bbl.
Old Jul 17, 2010 | 07:24 PM
Had a two bbl until I blew the motor, it was replacoed w/a '70 toro 455, but the mpg was when it had the original set up.
Old Jul 17, 2010 | 07:32 PM
that has ben my experience also.
Old Jul 19, 2010 | 05:48 AM
bullet1's Avatar
drove up to car craft on saturday about 200 miles round trip figured mine at about 15mpg.68 442 with original 400 and rebuilt original quad.not bad and a blast to drive.but i did blow two rear tires on the way home though ended up being a long day.guess the heat got to the old tires but now i can get new ones!!wife said i can only get parts i really need.
Old Jul 19, 2010 | 06:50 AM
MN71W30's Avatar
Did you have your 442 inside the fairgrounds?
If so, what color was it?
I checked out all the Oldsmobiles.
Old Jul 19, 2010 | 07:24 AM
bullet1's Avatar
had the green convertible i was parked next to dnr building on corner.
Old Jul 19, 2010 | 03:42 PM
MN71W30's Avatar
I checked it out. Nice car!!
Old Jul 20, 2010 | 07:08 PM
bullet1's Avatar
thanks.hopefully get a little more done for next year.front bumber ordered and looking for a set of tires.think im going with bridgestone but not sure what size will look good with stock rims.thinking 225 70's.
Old Jul 20, 2010 | 07:40 PM
Took my 72 Cutlass S out on the weekend for a car show down in Olds Alberta (Show was called the Rocket Roundup - 442much is the club prez). Anyway it ended up being a 347 mile round trip in one day. My car has its original 350/350 TH. 4bbl. 2.73 rear open. Average speed was 70 miles per hour. Average mileage was 21.5!!!! But then I was holding it pretty steady and most of the road was pretty flat. I had forgotten what those old 350's are capable of. I remembered it would go like a scared bunny, but was VERY pleasantly surprised that its mileage was so good. I think I should do a compression test to see whats left. Last time I did one, 6 of the cylinders were at 145, one was 135 and one was 140. Oh yeah, no oil use according to the dipstick and it still looks like it was just changed.
Old Jul 20, 2010 | 08:34 PM
firefrost gold's Avatar
worked most of the week end i missed the show i bet the skin factor was high on the flash o meter with the temp we had.
Old Jul 21, 2010 | 08:37 AM
MN71W30's Avatar
Wow,
Thats great mileage. Years ago I had a 67 Cutlass supreme convertible with a 330 4 bbl and a 4 speed, 3.90 gears get 19.2 mpg. I feel the 350 Olds engine was one of the best ever.
Yes it was very hot at Car craft.
jonstringer
Mar 4, 2021 03:54 PM
boc23
Drivetrain/Differentials
Aug 29, 2014 02:23 PM
monzaz
Aug 7, 2014 11:12 AM
monzaz
May 29, 2010 08:46 PM
Newkid8
May 29, 2008 05:19 AM
