Click Here
1972 cutlass supreme boltpattern/wheel dimensions
Old September 14th, 2011, 05:27 PM
hunter's Avatar
Looking to get cheap wheels to have fun with rubber soon; what are the wheel dimensions to place for a 1972 cutlass supreme convertible?
hunter is offline
Old September 14th, 2011, 05:28 PM
hunter's Avatar
and also what about the backspacing
hunter is offline
Old September 14th, 2011, 07:38 PM
DarrylJ's Avatar
The wheels are 14 x 7 with a bolt circle or 4 and 3/4 inch diameter. I am not sure of the backspacing, someone on here should chime in that knows.
DarrylJ is offline
Old September 15th, 2011, 09:40 AM
15x7 would be a better choice, given the tire sizes available today. Wheel OFFSET should be as close to zero as possible. On a 7" wide wheel, that would be about 3.75" backspacing. On an 8" wide wheel you want about 4.25" backspacing.
joe_padavano is offline
Old April 16th, 2012, 04:24 PM
Fasseddy's Avatar
would 3 1/4 back spacing on 15x 7" wheels on my 1968 cutlass work? i am looking to put 255/60/15 BFGs.
Fasseddy is offline
Old April 16th, 2012, 04:45 PM
Go back and read post #4
Old April 16th, 2012, 04:49 PM
Fasseddy's Avatar
I see the #4 post says "about 3.75" backspacing".
Too vague of a statement.
So for clarity: would 3.25" backspacing with 255/60 or 245/60 work without rubbing? I have 15x8 Torque Thrust Ds with 4.5" backspacing currently. Not liking the look.
Fasseddy is offline
Old April 16th, 2012, 04:53 PM
Fasseddy's Avatar
Here is what I have.
Fasseddy is offline
Old April 16th, 2012, 06:17 PM
It also says this:
Zero offset puts the wheel mounting flange right in the center of the rim width. That would be 3.5" for a 7" wheel. Since backspace is measured from the outer lip of the wheel, not the bead mounting surface, there's usually about an extra quarter of an inch added, which is how zero offset on a 7" wheel gets you 3.75" backspacing. I said "ABOUT" 3.75" because different wheels have different lip dimensions, so backspacing for the same zero offset could be up to 4". It can't be less than 3.5". At 3.25" backspacing, the offset will be close to 1/2".
donfitzgerald
July 4th, 2014 02:34 PM
e129745
Suspension & Handling
July 18th, 2013 02:48 AM
tmaleck
June 11th, 2013 12:01 PM
Abob89
July 23rd, 2008 04:43 AM
fahaka
May 29th, 2007 10:15 AM
Quick Reply: 1972 cutlass supreme boltpattern/wheel dimensions
