1972 cutlass supreme boltpattern/wheel dimensions
15x7 would be a better choice, given the tire sizes available today. Wheel OFFSET should be as close to zero as possible. On a 7" wide wheel, that would be about 3.75" backspacing. On an 8" wide wheel you want about 4.25" backspacing.
I see the #4 post says "about 3.75" backspacing".
Too vague of a statement.
So for clarity: would 3.25" backspacing with 255/60 or 245/60 work without rubbing? I have 15x8 Torque Thrust Ds with 4.5" backspacing currently. Not liking the look.
Here is what I have.
Zero offset puts the wheel mounting flange right in the center of the rim width. That would be 3.5" for a 7" wheel. Since backspace is measured from the outer lip of the wheel, not the bead mounting surface, there's usually about an extra quarter of an inch added, which is how zero offset on a 7" wheel gets you 3.75" backspacing. I said "ABOUT" 3.75" because different wheels have different lip dimensions, so backspacing for the same zero offset could be up to 4". It can't be less than 3.5". At 3.25" backspacing, the offset will be close to 1/2".
