Click Here
Painting SSI Wheels
Old June 8th, 2011, 03:55 PM
442dreamer's Avatar
Painting SSI Wheels
So probably a simple question but I'm a noob and I wanted to see what others have done to paint their SSI or SSII wheels. I have a 72 Cutlass supreme with SSI wheels that are faded to a dull gray with spots of surface rust around the lug nuts. I'd like to repaint them black, any tips? Thanks all!
442dreamer is offline
Old June 8th, 2011, 04:53 PM
vette442's Avatar
I've done several sets of SSIs. I usually degrease and sand the backsides and around the lug holes on the front, and even use a scotch-brite pad to get any loose black paint off of the painted sections between the spokes. I am careful not to scuff the spokes though. I then wipe everything down with lacquer thinner to degrease one more time. I use masking tape around the center hole and spokes then hit them with a few coats of satin black. Any excess paint that gets on the spokes can be easily scraped off with a blade after the tape is removed. Just use patience and they'll come out nicely.
Terry
vette442 is offline
Old June 9th, 2011, 02:52 AM
My442's Avatar
Thumbs up
2 layers of HD duct tape on the spokes and chrome areas. Trim with a razor blade.
Bead blast all the paint and rust off.
Degrease with laquer thinner
2 coats of an etching primer
2 coats of Eastwood Rally Wheel paint
My442 is offline
Old June 9th, 2011, 09:51 AM
442dreamer's Avatar
Great, thanks for the info guys!
Old June 9th, 2011, 11:09 AM
Lady72nRob71's Avatar
I just took all mine to the powdercoaters and let them do it all...
https://classicoldsmobile.com/forums...tml#post103267
It was 300 bucks for blasting and coating 5 wheels, but was worth it to me...
Bead (sand) blasting is the best way to get around in all those small nooks and crannies...
Lady72nRob71 is offline
Old June 9th, 2011, 09:14 PM
Chumley's Avatar
That's what I did with a set of SSII's. Powder coated with a semi gloss black. The car is metallic silver, so I thought the black wheels would balance well with the black vinyl top. I would post some pix, but they are at the shop right now. Chumley
Chumley is offline
Old June 11th, 2011, 07:35 AM
toro455's Avatar
Location: Issaquah, Washington ( 15 miles east of Seattle )
Are those tires still available ?
I'm just curious what kind of tires you have on your car ( photograph ). I've never seen anything like that....
toro455 is offline
Old June 11th, 2011, 09:04 AM
My442's Avatar
245/60 - 14 tires made by Jetzon.
A brand made by Cooper Tires.
My442 is offline
ttg
Wheels and Tires
27
October 31st, 2020 06:54 AM
wmachine
December 29th, 2011 07:17 PM
olds4life
June 14th, 2010 08:05 PM
wmachine
May 24th, 2010 06:02 AM
2blu442
November 20th, 2009 07:14 PM
Quick Reply: Painting SSI Wheels
