Click Here
67 offset..
Old July 30th, 2010, 06:22 AM
Getting There
Ranzan's Avatar
67 offset..
I`m almost at the stage of getting Rims.. fingers crossed..
I`m going to go with the new chromed aluminum Crager SS rims with spinners for the classic look... does anyone happen to know the backspacing I can get away with since my body is still off the frame?
Ranzan is offline
Old July 30th, 2010, 07:09 AM
ddx77's Avatar
I can check what mine are for you later if it will help, although I am not sure if my backspacing is the max or not.
ddx77 is offline
Old July 30th, 2010, 07:48 AM
Oldsmaniac's Avatar
I am pretty sure a 5 inch backspace on a 8 inch wheel will work. I had corvette wheels on my 67 conv which I believe are 4 inch spacing on an 8 inch rim and I had a little room to spare on the back side..... It is best to measure as you would not want to order wheels that wont work.
Oldsmaniac is online now
65 Delta Guy
December 25th, 2011 09:37 AM
STLCRZY
Suspension & Handling
August 18th, 2011 12:48 PM
Mark71
August 1st, 2011 03:03 AM
my72vert
January 1st, 2011 07:36 PM
1973olds98
Wheels and Tires
January 31st, 2010 10:22 AM
Quick Reply: 67 offset..
