Click Here
Vavle stems '66 toronado
Old October 24th, 2021, 03:28 PM
'66toro's Avatar
Looking to buy new valve stems for a set of ’66 Toronado factory chrome wheels to replace my original painted wheels. Valve stems I am seeing on e-bay and other places all list them as being for 1967- 1978 Toronado and Eldorado. My original painted factory wheels have the conventional straight rubber valve stem where as the new stems I am seeing are brass and angled, (pictured below); is there something different about ’66 Toronado wheels as far as what style of valve stem is correct or are the ones pictured correct?,,,thanks
'66toro is offline
Old October 24th, 2021, 03:35 PM
Oldsdruid
rocketraider's Avatar
The wheel design changed in 67 to accommodate disc brakes. For a 66 regular rubber snap-in valve stems will work fine.
rocketraider is offline
Old October 24th, 2021, 03:46 PM
'66toro's Avatar
Thanks; but will the brass angled stems also work?
'66toro is offline
Old October 24th, 2021, 04:01 PM
Oldsdruid
You could probably install them but they'd stick out at a weird angle. The 67-later brass stem holes are actually on the center section of the rim, behind the wheel spider.
Use the snap-in valve stems. They're what Oldsmobile specified for the 1966 wheel.
Or are the chrome wheels 67-70 design?
Old October 24th, 2021, 04:13 PM
'66toro's Avatar
Thank you again,,,
'66toro is offline
Greg-Z
August 28th, 2021 04:35 AM
Trailrunner
May 19th, 2017 09:16 AM
AZToronado1
April 26th, 2015 08:15 PM
Pete Kaczmarski
October 28th, 2014 06:52 AM
lester watkins
September 18th, 2008 10:27 AM
Quick Reply: Vavle stems '66 toronado
