Click Here
Getting ready to order
Old March 8th, 2018, 07:18 PM
CS-Bill's Avatar
1970 - Cutlass Supreme convertible (442 Clone)
455 - stock suspension - front disk brakes
So when buying this car my plan was to get all the little things squared away and then order the new wheels/tires and be all set for the first cruise night of the spring.
I know I want Cragar SS wheels and i think 15x7 is the right choice for the look I want. I don't want to stray too far from stock but do want to fill up a little more of the wheel well.
So am I on the right track with this wheel ?
http://www.jegs.com/i/Cragar/260/61C575040/10002/-1
And for tires I was looking to go with something in the 255/60-15 range, I believe that was a recommendation by Joe_P in one thread.
http://www.jegs.com/i/Mickey-Thompso...2/-1#reviewTab
Any and all opinions welcomed. Thanks in advance.
PS
Not opposed to other wheel choices if there is a better option fitment wise.
And a few pictures of what it looks like right now
File Type: jpeg
CS-Bill is offline
Old March 9th, 2018, 05:18 AM
Maintained
scottv442's Avatar
FYI....the wheel you show has a 5x5 bolt circle. You will want a 5x4.75 bolt circle.
other than that the rim size and backspacing is good for 255 60r15's
scottv442 is offline
Old March 9th, 2018, 05:39 AM
CS-Bill's Avatar
thank you !!!!
Then if I stayed with Cragar it would be this one
http://www.jegs.com/i/Cragar/260/61C573440/10002/-1
Specifications:
Backspacing (in.)4Beadlock FunctionalNoBeadlock IncludedNoCenter Cap IncludedYesHub CentricNoLoad Rating (lbs.)1,580Lug Nut Seat StyleConical seat - 60 degreeOffset (mm)0Primary Wheel ColorChromeQuantitySold individuallyValve Stems IncludedNoWheel Bolt Pattern (in.)5 x 4 3/4Wheel Construction2-pieceWheel Diameter (in.)15Wheel FinishChromeWheel Width (in.)7MaterialSteel/AluminumManufacturer's Part Number:61C573440
CS-Bill is offline
Old March 9th, 2018, 06:08 AM
Maintained
scottv442's Avatar
[QUOTE=CS-Bill;1080740]thank you !!!!
http://www.jegs.com/i/Cragar/260/61815/10002/-1
That rim is right for your car. same size and backspacing as the 1985-87 442 rim. If you want to fill the rear wheel well even more go to a 15x8 on the rear with 4" to 4.5" backspacing. 255 rear, 245 fronts
Old March 9th, 2018, 07:36 AM
CS-Bill's Avatar
My concern is ending up with an exaggerated look like this
No offense to whomever owns this car, it is just not the look for me.
I'm looking for something more subtle like this, and I think what you suggested would get me there.
CS-Bill is offline
Old March 10th, 2018, 07:08 AM
CS-Bill's Avatar
Thanks for the advice Scott, order placed. I will follow up with pics after they are mounted.
CS-Bill is offline
Old April 5th, 2018, 12:13 PM
CS-Bill's Avatar
Finally had the time to mount up the new wheels, thanks again for the advice Scott, this is exactly what I was looking for !!!!
CS-Bill is offline
Old April 5th, 2018, 12:20 PM
Sweet
Jamesbo is offline
Old April 5th, 2018, 01:43 PM
Maintained
scottv442's Avatar
looks great. happy motoring
Old April 5th, 2018, 02:22 PM
72 Olds CS
RetroRanger's Avatar
That looks smart bill....now put it away more snow predicted for mass tomorrow
RetroRanger is offline
Old April 5th, 2018, 02:41 PM
Looks good Bill
oldcutlass is offline
Old April 5th, 2018, 03:17 PM
CS-Bill's Avatar
Thanks guys, as mentioned above test ride will be postponed until after I shovel out the new snow that is coming lol If spring ever gets here I'll be ready for it
CS-Bill is offline
Diego
October 10th, 2016 06:28 PM
Almond900
August 3rd, 2016 11:52 PM
66-3X2 442
March 9th, 2014 07:50 PM
SkylinesSuck
July 29th, 2011 03:14 AM
Oldskool88
February 16th, 2008 01:46 PM
Quick Reply: Getting ready to order
