Click Here
Newer OEM wheels on an older car
Old May 9th, 2017, 08:22 AM
Roger60's Avatar
Looking to put a set of aluminum Trans Am WS6 wheels on a 67 A body. No fitment issues as to height or offset, my problem is finding a proper lugnut. The originals to the wheels are metric and the studs of course are not (7/16-20) Any ideas? Has to be a certain degree of taper to fit properly. Here are pictures of the wheels if anyone recognizes them. Thanks.
Roger60 is offline
Old May 9th, 2017, 08:58 AM
I don't see an issue using an sae lug nut as long as the beveled face of the nut seats against the wheel and there are enough threads engaging inside so that the proper applied torque can be applied without stripping.
oldcutlass is online now
Old May 9th, 2017, 09:23 AM
delete
droptopron's Avatar
McGard #64001 or 64011 should work fine. The angle is pretty standard
droptopron is offline
Old May 10th, 2017, 06:30 AM
The angle is standard, but the height of the cone is not. The aluminum wheels with taper seat lugs require lugs with a taller taper than those for steel wheels. Using the smaller taper lug nuts will allow the nuts to loosen and damage the wheels.
joe_padavano is offline
NelMurr
November 2nd, 2015 05:50 AM
Xavier777
February 24th, 2013 08:33 AM
Lady72nRob71
November 2nd, 2011 10:56 AM
Redog
June 1st, 2011 08:12 PM
Texas Jim
December 1st, 2009 01:39 AM
Quick Reply: Newer OEM wheels on an older car
